head removal
How do I remove the rear pushrods? Do I have to take the alternator off? Near that front hook on the head, what do I do around that. Loosen the belt and then remove alternator? Or is that not connected to the head? Thanks. |
#2 (permalink) |
Tech Specialist
Under the cowl there are two rubber plugs that you remove to allow the pushrods to go up through so you can remove them. The rear hole is up under the dash so you have to put the end of the pushrods up through the hole then they can be angled and will drop back down. Just take off the alternator bracket and leave the alternator mounted at the bottom. You'll probably have to electronically disconnect it though.
98 Dodge 2500 Motor: 12 valve, original 913 pump with the basics, some DDP parts, FASS, and more stuff then they will let me put here Drivetrain: 5-speed 4x4 w/ SB OFE clutch (Love it!) |
#3 (permalink) | |
#4 (permalink) |
No need to loosen the belt, remove the bolt holding the bracket to the thermo housing then loosen the bolt on the alternator and you can swing the bracket out of the way
96' 3500 Reg Cab 4x4 Leveled on 35"s HX35/40 Hybrid, Custom intake box w/ AFE BHAF, O-Ringed Head, Ported exhaust, 4" turbo back, 5x12's, #0 Plate, Gutted AFC |
#5 (permalink) | |
'97 4x4, 12 v, SC/LB work truck/DD probably a bad P7100 pump... Goerend VB and triple disc, Suncoast rebuild, Billet in/out, billet flex plate, 62/65/13ss +S475, Weston's 5x.014's |
#7 (permalink) |
Got everything out good and took it to the machine shop. They're gonna check the surface and let me know if it's needs to be resurfaced or not. I guess once you get past the exhaust system, the rest is a breeze. But #### those exhaust bolts were a pain. It's all good now though, hopin to get the truck on the road sometime next week.
#8 (permalink) |
I always put a lil Anti-seize on the manifold bolts before i put em back in...
#10 (permalink) | |
'96 Dodge 3500,KDP killed, boost-pyro-trans temp, not stock anymore '01 Dodge 2500 4X4, EC, LB, 6 speed, FP-pyro-boost, '97 Chevrolet Suburban, K1500, 4.10 gears |
