Old 11-04-2009, 02:12 PM   #1 (permalink)
Deisel Devin's Avatar
tranny trouble or something not sure.!!!
my truck going down the road it shifts in and out like really bad around 50- up like it wants to shift down and does it but then jumps back up then back down then up i have no idea whats going on.
'94 2500 Dodge Cummins Turbo Diesel 12 valve 4x4.
starwheel cranked, Custom intake with custom 5 inch stacks, silencer ring MIA, more to come.
Deisel Devin is offline   Reply With Quote
Old 11-04-2009, 03:49 PM   #2 (permalink)
Sounds like TPS
96' 3500 Reg Cab 4x4 Leveled on 35"s HX35/40 Hybrid, Custom intake box w/ AFE BHAF, O-Ringed Head, Ported exhaust, 4" turbo back, 5x12's, #0 Plate, Gutted AFC
Busted Knuckles is offline   Reply With Quote
Old 11-04-2009, 08:34 PM   #3 (permalink)
Super Moderator
Try this> TPS testing and adjustment
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Not stock
Old 11-07-2009, 11:26 PM   #4 (permalink)
Lots of great info about the TPS!!! Just wondering if the TPS is what causes mine to jump out of OD and the OD off light on the dash comes on. I have to press the button and then it'll go back to OD. Only happens once in a while but, at highway speeds when it jumps out, the RPMs get up in the 2,700+ range. If anyone has any info or has the same problem, would you please post your findings? Thanks, Dave.
hulkaman2003 is offline   Reply With Quote
Old 11-08-2009, 05:59 AM   #5 (permalink)
The TPS should not cause the OD switch light to come on. Sounds like a bad switch or short in that circuit.
RPegram is online now   Reply With Quote
Old 11-08-2009, 07:25 AM   #6 (permalink)
JohnBer's Avatar
mine did that to me a few times. there was no rhyme or reason to it. installed a new switch and it has not done it sinse. oh, it's been a year now sinse i replaced the switch. think it had somthing to do with coffee from the cup spiller right next to it.
Dog's truck:95 2wd ex, built auto, kdp tabbed, 3 disc billet converter,3.54 gears, 4gsk, bhaf, 0 plate, rack plug, 90hp injectors, 191 DV's, htt 62/71/14, timed @17*, 60# valve springs, head studs, 5" exhaust, gauges
JohnBer is offline   Reply With Quote
Old 11-18-2009, 02:21 AM   #7 (permalink)
JohnBer,
Thanks for the info, I changed the switch and so far, so good. I appreciate the response, I imagine that the 44 oz Mountain Dew may have had something to do with it. Dave.
Old 11-18-2009, 02:03 PM   #8 (permalink)
sayiwont20's Avatar
hey man, i have the same problem with my 94 12 valve, and i still cant figure it out, i was told to check any grounds that link to tranny, batteries, or alternator, and the altornator also comes loose from belt pressure, if you find any info could you also help me out? thanx
sayiwont20 is offline   Reply With Quote
Old 11-18-2009, 11:16 PM   #9 (permalink)
sayiwont20,
JohnBer suggested changing the switch, which I did, and haven't had it jump out of overdrive since. I wouldn't doubt that pop or coffee ended up in it at some point years ago. I can't understand how your alternator is coming loose under belt tension. The serpentine system uses an idler pulley and tensioner to maintain belt pressure and the alternator should be rigidly mounted to the alternator bracket. Am I missing something? I've also seen where the TPS can cause erratic operation and shifting. Have you performed the TPS tests listed previously on this post? I'll try to be as helpful as I can. Dave.
