Old 11-04-2009, 11:33 PM   #13 (permalink)
ykdave's Avatar
Originally Posted by ozarkdiesel View Post
Have you checked the solenoid with the key on and see if its up? If not pull it up manualy and c if it starts.
The solenoid will not pull up until the starter is engaged!
97 Ram 2500 / 5.9ctd /NV4500/241DHD
Custom Intake Tube+ BHAF, Pump Tuning, Autometer Pyro and Boost gauges, Dual 4" stacks, 33x12.5 Mud terrains, posi-lok, One Hella sound system, tons more to come
ykdave is offline   Reply With Quote
Old 11-05-2009, 12:37 AM   #14 (permalink)
M K
clean the relay & the connections & use electrical gease & I did not have any starting problems today ,I hope that took care of the problem but only time will tell .
97 - 2500 club cab 8ft box , 2 wheel drive auto trans 4:10 rear end , BHAF,heat shield & AFE intake tube, Autometer boost, pyro ,trans temp guages , stock afc plate moved forward , AFE 4" stainless turbo back exhaust , Alpha bed liner ,repainted white
M K is offline   Reply With Quote
Old 11-07-2009, 10:51 AM   #15 (permalink)
M K
It looks like cleaning the fuel shut off relay & connections with electrical contact cleaner & using the electical grease has taken care of my starting problems . The truck has been starting fine for the last 3 days , I would like to thank everyone for their advice .
Old 11-07-2009, 12:30 PM   #16 (permalink)
When my relay went bad, I could just unplug and plug it back in and would work for 1-4 days and then I would have to do it again. If that happens to you, then I would replace the relay.
RPegram is offline   Reply With Quote
