Old 11-04-2009, 12:18 AM   #1 (permalink)
12VRattler's Avatar
Fuel Injectors
After changing my headgasket I seem to have some leaks on my injectors. Near as I can tell it seems it is running up out of the injector holes around the lock nut that secures the injector in place. I have new washers on the tips of the injectors and new washers on the return but am getting quite a bit of fuel pouring out on injector 1 espicially and seeping out of the rest slowly. Any ideas as to what I am missing or has anyone else had this problem?
1996 2500 12v/nv4500 4x4 335k miles and still going strong!! KDP tabbed, Amsoil 4510 BHAF, evicted silencer ring, plugged wastegate, 5 inch FBE muffled, #100 plate, Isspro boost and pyro, Mickey Thomson ATZ's 285/75R16's, B&W steel flatbed
12VRattler is offline   Reply With Quote
Old 11-04-2009, 09:03 AM   #2 (permalink)
Some people have problems because they didn't clean out the carbon under the copper washer.
1994 Reg cab 2 WD manual trans #0 fuel plate boost elbow BHAF 16.5* 3KGSK KDP fixed
tdshepard is offline   Reply With Quote
Old 11-04-2009, 02:18 PM   #3 (permalink)
calebmcclellan's Avatar
Silver Seal Products Cummins Injector Cleaning Brush
86 C/20 w/94 12v 420k miles http://www.cumminsforum.com/forum/cu...chevy-2wd.html
92 W250 just got it
calebmcclellan is offline   Reply With Quote
Old 11-04-2009, 08:36 PM   #4 (permalink)
12VRattler's Avatar
I guess I'll be pulling the injectors again to clean the holes out....I think that a 12 guage brush would work well but if it doesn't I will order one from the linky provided
Old 11-04-2009, 09:22 PM   #5 (permalink)
Tech Specialist
Make sure its not leaking from the return line/bolts, a lot of people have trouble getting them to reseal.
98 Dodge 2500 Motor: 12 valve, original 913 pump with the basics, some DDP parts, FASS, and more stuff then they will let me put here
Drivetrain: 5-speed 4x4 w/ SB OFE clutch (Love it!)
Dual K20s is offline   Reply With Quote
Old 11-04-2009, 09:24 PM   #6 (permalink)
And a good douche with brake cleaner. In my notes I have injector nut torque at 44 ft. lb, return line torque at 80 inch lb, and 28 ft lb on the high pressure line nut........
Old 11-05-2009, 07:32 PM   #7 (permalink)
12VRattler's Avatar
I got all new washers again from cummins so I will try it again this weekend. At cummins they gave me the option of 7mm or 9mm washers under the injectors. I didnt have a clue and took the 7's because thats what the guy said they use most often, is that right? What would the 9mm's be for?
Old 11-05-2009, 07:37 PM   #8 (permalink)
ykdave's Avatar
He meant the diameter size of the injector tip. the older engines (mainly the non turbo) used a 9mm tip and the heads were really prone to cracking. Around the era of the p-pumped engines they had switched to a 7mm tip so they could leave some more meat in the head to prevent cracking.
97 Ram 2500 / 5.9ctd /NV4500/241DHD
Custom Intake Tube+ BHAF, Pump Tuning, Autometer Pyro and Boost gauges, Dual 4" stacks, 33x12.5 Mud terrains, posi-lok, One Hella sound system, tons more to come
ykdave is offline   Reply With Quote
Old 11-05-2009, 08:40 PM   #9 (permalink)
B,C Series 5.9L Injector Installation Kit (6)
I had very good luck with this kit. Even with shipping it is a bargain. The horseshoe washers are good and thick.
I used the thin washers with my injectors from a 215 hp engine.
The Following User Says Thank You to tdshepard For This Useful Post:
12VRattler (11-06-2009)
Old 11-06-2009, 11:43 PM   #10 (permalink)
12VRattler's Avatar
Well I add a little more to my knowledge bank everyday! Its amazing the difference that 2 mm can make. I already picked up my copper washers from cummins but wish I had picked up that kit, it has everything and is almost half what I paid for just 6 washers and horseshoes....
