Wastegate Question
After reading other posts about boost pressure I realized mine was pretty low. Gauge reads 1lb at 65mp/1750RPM and max I have seen is 20lbs during WOT. I checked my boots and plugged the line that goes from the AFC to the waste gate resulting in no change. Is it possible for the waste gate to be stuck in the open position causing low numbers? My egt's are at 600* @ 65mph and rise fast with the throttle. All mods are in sig, what so you guys think? Thanks
95 CTD 2500 STD Cab 4X4, KDP Tabbed, Boost/Pyro, AFE Stage II, 4" MBRP Exhaust, ATS Exhaust Manifold, BD T/C and Trans w/ Torq Loc, DDP STAGE II INJECTORS, #10 PLATE, CFM+ Intake, HID Head lights, ROL BAK Cover, 2" leveling Kit |
#2 (permalink) |
I think that stock is set around 20lbs. I know this will not help but I would like to turn mine down , it is easy for me to hit 35lbs without trying and I do not want to blow my head gasket. I have a little elbow valve to control it but have no idea weather to turn the allen screw in or out to decrease the amount of boost
1998 3500 quad cab 4x4 12v 5spd, 4:10 gears, US Gear Dual Range, 5" Stacks, boost elbow, 3 piece exhaust manifold, pyro/boost gauges, unknown pump mods? |
#3 (permalink) |
I would think that if you open the valve up by moving the allen screw out it'll decrease the psi. You could just back it most of the way out and see what that gets you. Is 0-1 psi boost low on the freeway or normal? Also with the afc to waste gate blocked I thought the boost would increase?
95 CTD 2500 STD Cab 4X4, KDP Tabbed, Boost/Pyro, AFE Stage II, 4" MBRP Exhaust, ATS Exhaust Manifold, BD T/C and Trans w/ Torq Loc, DDP STAGE II INJECTORS, #10 PLATE, CFM+ Intake, HID Head lights, ROL BAK Cover, 2" leveling Kit Last edited by Badger : 11-03-2009 at 11:14 PM. |
#4 (permalink) |
I will try that
#5 (permalink) |
Is there a direct relationship between low boost and increased egt's?
#6 (permalink) | |
1994 Reg cab 2 WD manual trans #0 fuel plate boost elbow BHAF 16.5* 3KGSK KDP fixed |
| The Following User Says Thank You to tdshepard For This Useful Post: | Badger (11-04-2009) |
#7 (permalink) |
I had the same problem on mine where the wastegate was stuck partially open and solved it by shoving a shim in it as you mentioned. I believe as you screw the allen head in on the boost elbow it slows the boost signal to the wastegate allowing you to build more boost before it starts to open. All the way in should be like having it plugged off completely.
1996 2500 12v/nv4500 4x4 335k miles and still going strong!! KDP tabbed, Amsoil 4510 BHAF, evicted silencer ring, plugged wastegate, 5 inch FBE muffled, #100 plate, Isspro boost and pyro, Mickey Thomson ATZ's 285/75R16's, B&W steel flatbed |
#9 (permalink) |
I'll look over the line. If it is kinked will straightening the line back out be ok or is it better to shorten the line? After a kink it'll usually cause a change to the inside diameter.
#10 (permalink) |
Moderator
![]() Join Date: Nov 2005
Problem with most boost gauge tubing is once it's kinked it's very hard to keep it from kinking again in the same place. If you thread the small tubing though some larger tubing it will keep it from kinking again.
Bill '95 2500 4wd auto '95 3500 5 speed heavy hauler Not stock |
| The Following User Says Thank You to illflem For This Useful Post: | Badger (11-05-2009) |
#11 (permalink) |
Installed new boost elbow and a 14cm exhaust housing w/ waste gate and still had low numbers so, I ended up pulling the gauge out of the pillar mount and located a kink that was a result of putting the gauge in the pod. Boost hit 35 after that. Thanks for the information.
