Old 11-03-2009, 01:01 AM   #1 (permalink)
let the truck idle for abotu an hour and no coolant
i was tryign to warm somethign up so i left the truck idlign for abotu an hour. later when i drove home abotu 15 min into the drive the heater stopped working.
stopped and sure enough i was super low on coolant.
no cracked block. no weird smoke out the tail pipe, not power issues.
i have a wird chirping noise commign from the front left of the block. i thoguht it was the belt tensioner bearing but could it be a water pump?
its been chirping for abotu a year.
1999 4x4 ext cab Short Box.
Auto | Juice w/Attitude | Magnaflow 4" | BHAF | 3.25 Turn Steering Box | HID conversion | Transgo Shift Kit |
Kraqa is offline   Reply With Quote
Old 11-03-2009, 01:12 AM   #2 (permalink)
could be the water pump. how did u get so low on coolant and not notice sooner? did you have a leak?
2000excab2500 16" ultra mako's with 35" hankooks, leveled,full suncoast, HRVP, II phat shaft 66, 200's, air dog 150, allthe gauges, afe intake, 5" tbe 6" tip, intake horn by me, 5%tint, 35% windshield.
whitebullet3 is offline   Reply With Quote
Old 11-03-2009, 01:35 AM   #3 (permalink)
12vbigkermit's Avatar
check your oil. see if u have cross contamination. kinda hard to loose coolant unless someone put water and it evaporated.
98 2500 4x4 7"38's, 8kh.i.d, pump tweaks, 4gsk, stacks, inline defuser,FASS,gauges,Suncoast billet trans bllt flex plate, tc lck up, timing, k&n, head oringed+ stg3 valve job,60lbs spring,coaltrain 140's soon to be a1's and super b special.
12vbigkermit is offline   Reply With Quote
Old 11-03-2009, 03:12 PM   #4 (permalink)
gary502's Avatar
my water pump only dumped water when i was driving...never really when idling...i had the same problem....look up under the truck at the water pump and see if the weep hole on the bottom looks wet....id betcha thats ur problem...
95 2500 4x4 5 speed, reg cab, 12 valve, 50hp injectors, fuel plate DELETE, 5'' stacks, 33'' mud terrains, valair single disk.
gary502 is offline   Reply With Quote
Old 11-03-2009, 03:16 PM   #5 (permalink)
ykdave's Avatar
Ill take a vote for water pump.
97 Ram 2500 / 5.9ctd /NV4500/241DHD
Custom Intake Tube+ BHAF, Pump Tuning, Autometer Pyro and Boost gauges, Dual 4" stacks, 33x12.5 Mud terrains, posi-lok, One Hella sound system, tons more to come
ykdave is offline   Reply With Quote
Old 11-03-2009, 03:23 PM   #6 (permalink)
does your oil have a milky color. if i does i say bloen head gasket if not probably just the water pump
94 Dodge 1500 black regular cab 2wd powered by a 2005 Cummins 3.9 4BTAA 27mpg (Friends) 95 Dodge 2500 4x4 boost elbow (35psi) #6 fuel plate http://www.cumminsforum.com/forum/cu...ics-truck.html
JakeDiesel is offline   Reply With Quote
Old 11-03-2009, 07:12 PM   #7 (permalink)
Bluedually4x4's Avatar
If it was a head gasket he would have oil in the coolant, not coolant in the oil. Oil pressure is higher than coolant pressure.
1998 3500 4x4 5 speed reg cab dually
TST #10, ATS exhaust man, 5" turbo back exhaust twin 5" stacks, SB 13.5 clutch, BHAF, 75 hp injectors
Bluedually4x4 is offline   Reply With Quote
Old 11-04-2009, 01:41 AM   #8 (permalink)
no oil in either coolant or oil.
i'm guessing water pump. thnx guys!
it does have 190,000 miles on the original WP.
Old 11-04-2009, 08:46 AM   #9 (permalink)
B.B.'s Avatar
Not really answering your question, but I would not idle the engine to warm it up when cold. Once it smooths out after 20 seconds or so, maybe less, maybe a tad more, drive it slowly and don't work it until up to temp. Letting the truck idle when cold isn't the best for it.
97 3500 DRW
03 3500 DRW
B.B. is offline   Reply With Quote
Old 11-04-2009, 09:28 PM   #10 (permalink)
i was idling it to turn the heat on and warm the memory foams up inside the tires of my RC crawler at an out door comp.
lol
wow that sounds bad.
Old 11-04-2009, 10:33 PM   #11 (permalink)
okay most leaks are exhuast in to the coolant have a garage do an exhuast gas test. takes 5 minutes to do. very simple. most coolant leaks will be external. coolant pressure is about 15 oil is 40-80 exhuast 100+
2low4nh is offline   Reply With Quote
Old 11-05-2009, 01:16 AM   #12 (permalink)
I'm fed up with the truck.
time for a new one.
