WIF light after filter change - Dodge Cummins Diesel Forum
Old 10-22-2009, 12:19 PM   #1 (permalink)
I changed the fuel filter and now the WIF light is on. I guess I have to drain the filter to remove the water, but I have no idea why water would be in there or how the light went on in the first place. I have changed many a filter before and this is the first time something like this has happened. Any ideas or help would be appreciated. Thanks.
96 reg cab, 5sp long bed 4x4: 10 plate, 3GSK, pump @15, AFC altered, K&N, gasket matched and ported exhaust manifold, 4" exhaust, gauges, KDP KO'ed, Dynatrac axles and hubs (don't go there, bad product, bad customer service), airplane landing lights, Dana Powerlok's front & rear, runs on WVO.
Baja is offline   Reply With Quote
Old 10-22-2009, 02:25 PM   #2 (permalink)
cjensen91910's Avatar
If the two wires going to the WIF are shorted you get a light. If anything got on the sensor while it was apart you will get a light. If the connector gets wet with any thing that will conduct electricity you will get a light. Connector should be filled with dielectric grease to stop any shorts.
95 Auto, billet TC and modded valve plate, BHAF, Aux lift pump, three position lockup switch, full gauges, #5 plate, no muffler and CAT is gutless. Timed at 15.5, full EGR brake package.
cjensen91910 is offline   Reply With Quote
Old 10-22-2009, 09:16 PM   #3 (permalink)
When I changed mine for the first time the light was on when I was done. Read on here that it might be screwed in too tight. I backed it out about 1/2 a turn and the light went off. Didn't leak and no problem since then.
94 Dodge 2500 regular cab, slowly upgrading, rebuilt auto, single disk billet T/C, BHAF, 10 plate, MBRP 4" exhaust, 3K GSK
scentral mt is offline   Reply With Quote
