Old 11-04-2009, 03:03 PM   #121 (permalink)
Rogan's Avatar
Originally Posted by LaMoparPower View Post
so basically a quick rundown is the
A) #10 plate and boost elbow - $36 shipped from importstorage - Dodge Cummins Diesel Fuel Torque Plate Design # 10 1PC :eBay Motors (item 200311791485 end time Nov-15-09 11:51:41 PST)
B) Starwheel cranks - free
C) pull tranny line - free
D) afc mod - free
E) straight pipe - $55 for a 4' section of 4" slip-fit, 2 4" clamps, a 3" clamp, and a 3" x 4" adapter.
miss anything? im going to order all my parts today..
what i paid, is above, in RED..
Originally Posted by MX26 View Post
That will get you going. And, if you're looking for another way to control the wastegate, just clamp it off. Follow the tube going out the backside of the wastegate across the valve covers, and just plug it with a bolt and a hose clamp. You can do it there, or just take it off the bottom of the WG itself.
I plugged mine off (pinched it closed, anyway) and didn't see any real difference. I did, however, see huge boost increase with the #10 and boost nipple.
'96 RAM2500 CTD SCLB 4x4 Auto, 3.5:1 D70 LSD - BHAF, KDP fix, catless 4" with turn-down after the cab, 3K GSK, #10 torque plate, boost/pyro gauges, 5th wheel setup, Pioneer cd player, crank-em-up windows - otherwise, it's a boner-stocker
Rogan is offline   Reply With Quote
Old 11-04-2009, 03:05 PM   #122 (permalink)
Super Moderator
LaMoparPower's Avatar
thanks guys... just wanted to make sure i hadnt missed anything...
96' CCLWB 4x4, 22's, blacked out.... still has factory cat and muffler! its a work in progress
Big Thanks to Wally At FTEDiesel!!!!!
Enter the FTE FASS giveaway HERE!!!!!!!!!!!
LaMoparPower is offline   Reply With Quote
Old 11-04-2009, 03:05 PM   #123 (permalink)
Deisel Devin's Avatar
never mind your questions have been answered
Diesel Devin
'94 2500 Dodge Cummins Turbo Diesel 12 valve.
starwheel cranked, Custom intake with custom 5 inch stacks.
Deisel Devin is offline   Reply With Quote
Old 11-04-2009, 03:07 PM   #124 (permalink)
where did you get your mirrors for your truck and how much were they.
Diesel Devin
Old 11-04-2009, 03:09 PM   #125 (permalink)
Super Moderator
they are kool-vue mirrors.... i wired them up so id still have power... they ran me $300....
i guess i need to order the GSK also... those are about $100 correct?
Old 11-04-2009, 03:13 PM   #126 (permalink)
MX26's Avatar
Well Duh! Did you try it with the #10 and the WG plugged??
And yes, the 3GSK kit is around $100. I ordered mine from Piers Diesel.
Trust me.... I'm a doctor.
94 12V NV4500 2wd - #100FF, BHAF, 3GSK, 4" FBD Straight
98 12V Quad Cab Shortbed SLT 4x4 - Auto with a "few" mods
MX26 is offline   Reply With Quote
Old 11-04-2009, 03:16 PM   #127 (permalink)
Super Moderator
any more tricks Mr. Rogan or myself should be aware of?
Old 11-04-2009, 03:25 PM   #128 (permalink)
MX26's Avatar
That's just about it for the cheap stuff. The next step is all internal, or expensive. You could upgrade your DV's, but the stock DV's do fine for stock injectors. You could upgrade your injectors, but you'd be running hot and would need a bigger turbo to cool it down. That would put you in desperate need of a clutch/tranny.
I feel like both of you will be pleased with the performance you've got after upgrading the fuel plate & throwing some GSK's at it. Honestly? The plate is the most noticable HP factor, but the GSK's are what make the truck fun to drive. I would recommend upgrading the stock air cleaner though. If you want to go the direction of a BHAF, they can be had for a reasonable price. If you're looking to keep a stock-type filter, go ahead and cut the side out of your airbox that faces the fender. Both of these will greatly help the suction side of things.
Oh, one more thing. You could both benefit from having your timing advanced to 15.5* or 16*
Old 11-04-2009, 03:27 PM   #129 (permalink)
Super Moderator
how is this done? I always thought this is what the starwheel did.... or does it involve pulling the front cover and actually advancing the cam?
Old 11-04-2009, 03:33 PM   #130 (permalink)
MX26's Avatar
The starwheel controls pre-boost fueling, not timing. And yes, you would be advancing the cam. Do a search on here and you will turn up TONS of info on doing it, but I have done the same thing and concluded that it's too much of a PITA for me to do myself, and will take it and have it done. Good time to kill the KDP while you're there.
Old 11-04-2009, 03:44 PM   #131 (permalink)
Super Moderator
thats why i was asking... i did my KDP 3 weeks ago.... o well... i htink the timing can wait for now
thanks again for all the help guys!!!!!!!
Old 11-04-2009, 09:55 PM   #132 (permalink)
Rogan's Avatar
i couldn't find anything, other that pump timing ...
