truck hung up in 5th - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 09-18-2009, 01:46 PM Thread Starter
caleb_1997's Avatar
i was on my way to school this morning and it got hung up in 5th gear. got a guy to come fix it and it did fine until i went to take it out of 5th again. he said it may be a syncro or a shift fork. any opinions. thanks
2006 3500 4x4 6 speed 145000 miles. diablo sport predator 5" in straight
caleb_1997 is offline
post #2 of 4 (permalink) Old 09-18-2009, 09:41 PM
It's a pretty common problem and not expensive parts wise.
If you baby it and shift into 5th straight on it can be avoided until repaired.
Call the guys here Dodge NV4500 and they will explain it better than I can.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #3 of 4 (permalink) Old 09-20-2009, 09:43 PM
My grandfather had the same kind of deal if you sift it straight in and out it will not hang if it is the shift fork. I wouldnt think a syncro would cause it to hang in gear but not grind going in hope that helps
2014 ram 3500 4x4 6 spd cc all factory equipment.
aharrel410152 is offline
post #4 of 4 (permalink) Old 09-21-2009, 03:03 AM
1997whitefozo's Avatar
possibly could be the same problem as mine. Theres these little flat clips with springs behind it, that hold the slider in position on the gear. (hard to explain) and one of my flat peices broke, got wedged in between the slider and the gear, holding the slider and forcing it to stay on the 5th gear syncro.
Fattie 04.5 qcsb 64 over s475, Flux 3's, full billet trans, ARP 425's, AD165, 35's, Thuren goodies, stock cp3, best 12.6 1/4 mile w/6" lift and 37's.
1997whitefozo is offline
