Water in fuel - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 09-06-2009, 02:10 PM Thread Starter
Water in fuel
Ok so i noticed my Water in Fuel light was on today. Not sure when it came on, but i know it at least didn't happen untill i accidently grounded out the battery.
well i drained about a pint of fuel out through the separater, all looked clear, the truck runs fine, no hesitation, no sputtering, no idling issues, but the water in fuel light is still on. do i need to reset it or something?
1995 Dodge Ram 2500 4x4
1997 Dode Ram 3500 4x4. Has to be mostly slow and free because all the money went into the 2500
nick112207 is offline
post #2 of 14 (permalink) Old 09-06-2009, 04:13 PM
Armchair Mechanic
colin91's Avatar
the sensors on the bottom of the fuel filter can go bad. probably just need to replace it
FLEETGUARD - REPLACEMENT WATER-IN-FUEL SENSOR (89-96 DODGE)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
1996 2500 ECLB, NV4500, 4X4
Engine: Hamilton 182/214/106, P&P+O-Ringed Head, Hamilton HD pushrods/retainers/springs, Adj. Timing Gear at 20*, ARP 625+, 20 Over Big Bowl Pistons, ATS 3 Piece Manifold, Fluidamper, Southbend DD3250, 5" Turbo Back Exhaust + FTE Resonator
Air: Crazy Carl's Twins - S362/65/.70 over S475/83/1.10
Fuel: PDD 5x14s (SAC 155* @ 290 BAR), PDD 055 DVs, AirDog, Dual Feed, AFC Live Stage 1, 4K GSK
Suspension (So Far): Thuren 3" Coils, Thuren Torsion Sway Bar, Thuren Track Bar, DOR Shackle Flip, Metal Cloak Short Arms, Fox 2.0 IFPs
colin91 is online now
post #3 of 14 (permalink) Old 09-06-2009, 04:42 PM
The Cheyenne Kid's Avatar
sometimes the wires coming out of the sensor get striped or they get pulled a little bit out of the sensor which allows them to touch and thus turn on your WATER IN FUEL light. you might check to make sure thats not what happened before you buy a new sensor
'97 RAM 2500 Laramie club cab 4x4, new Stock Auto Tranny, straight exhaust with 5" chrome stack, Star Wheel Turned Up, boost trans temp and pyro gauges.
The Cheyenne Kid is offline
post #4 of 14 (permalink) Old 09-06-2009, 05:03 PM
mor4wd's Avatar
I'd try disconnecting your batteries for a couple minutes, then reconnecting and see if that gets rid of it. My Water in Fuel light came on when my Trans Temp Sensor went out, fixed it and it went away.
1998 12 valve QCLB 4x4
2011 Ford F350 CCLB Lariat
SOLD - 1995 12 Valve CCLB 4x4
mor4wd is offline
post #5 of 14 (permalink) Old 09-06-2009, 05:17 PM
Stump Jumper's Avatar
How much have you drove it since draining it? When my light came on after draining it took 5 miles for it to go off.
97 12 valve HX40/HT60 Twins, 0 plate FF, 2095 plug, AFC tweaked , 4k gov, 16*, Weston's 5X.014s, 5in from turbo to stack, Twin Ram, HTT manifold SB 3250 DD Gauges up the wazoo.
Stump Jumper is offline
post #6 of 14 (permalink) Old 09-06-2009, 05:17 PM Thread Starter
alright. thanks. i'll be back if what you guys suggest doesn't work haha
post #7 of 14 (permalink) Old 09-06-2009, 05:18 PM Thread Starter
i'd say i drove a good 15 miles.
on a side note i figured out what happens when you drain most of the fuel out of the filter and cause air pockets to develope in your fuel system haha
post #8 of 14 (permalink) Old 09-06-2009, 06:17 PM Thread Starter
i'm confused as to where the sensor is. I can neither FEEL nor SEE any wires that are attached to the fuel drain. can't even see any loose wires around the separator.
post #9 of 14 (permalink) Old 09-06-2009, 08:39 PM
The connector is probably hanging down in the area below the filter and has water or gunk in it shorting making the light come on.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #10 of 14 (permalink) Old 09-07-2009, 12:04 AM Thread Starter
well i felt all around the drain plug thing, no wires attached. no wires anywhere on the filter, even climbed under the truck, and looked up, and saw no wires attached to it anywhere.
post #11 of 14 (permalink) Old 09-07-2009, 04:53 PM
If you can't find a loose connector in the filter area someone must have got frustrated trying to disconnect the sensor connector and just cut the wires.
I'd look for two wire stubs and make sure they aren't shorted together.
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
post #12 of 14 (permalink) Old 09-08-2009, 03:23 AM
calebmcclellan's Avatar
iTrader Score: -1 reviews
find the connector and unplug it then your WIF light will go off forever
86 C/20 w/94 12v 420k miles
calebmcclellan is offline
