96' 12valve tranny problems - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 08-11-2009, 09:55 AM Thread Starter
I have a 96 duelly 4x4 with a 47re that will not shift from 2nd to 3rd gear when the tranny gets warmed up inless I let off the go pedal.It shifts fine when you fisrt take off when the tranny is cold. It doesn't slip it just won't shift. Any help would be greatly appreciated thanks.
gagersram is offline
post #2 of 10 (permalink) Old 08-11-2009, 12:33 PM
Are you sure it's 2->3 shift and not 3rd to overdrive?
95 Dodge 2500 6bt, 47RH, NP241, Dana 70 LSD, 60, Silencer Ring removed, #6 Plate, BHAF, -> drivetrain going into 1950 Willys Wagon
49 Willys Pickup, 4bt, HX-35, T19, divorced 205, Dana 44's
CtrlAltDl is offline
post #3 of 10 (permalink) Old 08-11-2009, 02:54 PM Thread Starter
positive 3rd to overdrive is fine its 2nd to 3rd
post #4 of 10 (permalink) Old 03-09-2010, 10:53 PM
Don't mean to Hijack but my 98 auto does the same thing but it is from 3rd to overdrive. Any ideas? I also found out my fuel plate has been removed! I have only owned the truck 6 weeks and have plowed snow in it quite a bit.
no1cummins98 is offline
post #5 of 10 (permalink) Old 03-12-2010, 12:47 AM
i just got a 96 to day and test drove fine (wile tranny was cold) after warmed up it was sticking in second bad also. after driving on freeway for about 60 miles started to shift fine again.
mudintoy is offline
post #6 of 10 (permalink) Old 03-12-2010, 01:10 AM
WUTNOIZE's Avatar
http://bionicdodge.com/Download/Dodg...Adjustment.pdf
1997 3500 Dually 4x4 ,5 spd, 241DHD,410's,#10 Plate,Tuned AFC, Ajustable Boost Elbow, KDP Jigged, , 4" Turbo back, 19.5 Alloy Wheels/245/70R19.5, Level Kit, 5100 Bilsteins,BDD Tracbar/Steer box stab , Poly Bushings, Isspro Guages Pyro-Fuel-Boost1Orig Owner
WUTNOIZE is offline
post #7 of 10 (permalink) Old 03-12-2010, 06:28 AM
If you're just counting shifts, you are actually sticking in 3rd and not shifting into OD. Multiple things can cause this, but first to suspect is TPS since it can wear and give problems quite often. Your trans is controlled by a combination of electronics and hydraulic pressure, so you could have one or several problems. Only way to diagnose is combination of checking electronics and pressures. You'll need a factory service manual for this as the diagnostics for these trans takes many, many pages to cover. Geno's Garage is the most inexpensive place to find one of these (around $30 on CD).
RPegram is offline
post #8 of 10 (permalink) Old 03-25-2010, 03:57 PM
mine seems to be working better since i adjusted the tv cable and put in a 3k gsk. i think it was just wanting to shift at the point that my engine started to defuel the tv was cranked and would not shift till just over 2k i moved it out little and shifts lower now. have not drove much since the changes but got my fingers crossed the the prob is solved.
96 25004X4,boost,egt,trans temp,triple loc conv, shift kit,fass 150,4' exhaust, 3k gsk,k&n air filter holes in bottom of box(soon to be #8 plate)
mudintoy is offline
post #9 of 10 (permalink) Old 03-25-2010, 04:21 PM
Algae Eater's Avatar
iTrader Score: 7 reviews
Make sure your TV cable wasn't adjusted out too far (loose / slack) because that can cause worse trans problems like super high temps.
Have a friend help to see if the TV arm (on tranny) starts moving as soon as the accelerator is pressed at all. And also that at WOT, the arm moves to its fully open position.
Proper TV adjustment is pretty crucial.
98' 12v QCLB 4x4 216k, S363/68/.83 + S478/87/1.1, Steed T4 manifold + JGS gate, Levi's Blankets, A1 studs, Goerend, 5x18 SAC, 042DV, 2095, 4GSK, TerraG 295/17's on 4thGen 6-spokes
Algae Eater is offline
post #10 of 10 (permalink) Old 03-25-2010, 04:26 PM
it is not getting any hotter than it was sensor in pan and will get to 150 around town and shift god and firm. will check it out more when i can get a spare foot just to make sure.
mudintoy is offline
