Old 07-27-2009, 01:24 PM   #1 (permalink)
torquing head studs
I have read a few articles and I want to torque my head studs down more but dont know if I should take them out to oil them or just torque them down more 5lbs at a time.
I was thinking I dont want to take them all out because it would take pressure off the head gasket so I was thinking I could take out one, oil it then torque in down to where it was, then after I do that to all of them in sequence I could start torquing then 5lbs at a time to 125lbs. Anyone see any issues with this way? Thanks
1995 Auto 4x4, 100 plate, 3gsk, upgraded tranny, lockup switch, BHAF, KDP tabbed, guages, 4in TBE, and some leather seats from a 01.
BradenAnders is offline   Reply With Quote
Old 07-28-2009, 11:37 AM   #2 (permalink)
12valveterror's Avatar
what i did was loosen um all up and then check um for oil, mine still had alot of oil on them so i put im back in made um tight too 100lbs then followed the torque pattern and went in 10 and then a 5lb increment up to 125, you could still keep um tight and go from there, im fairly sure my head was never touched and had a lot of oil on them bolts but do it rightthe first time pull um and check um just to make sure
97' 2500 12V, 4x4, Auto, Dunrite Triple Disc T/C & V/B, 4k-GSK, Bilstein 5100 Shocks, DSS Stablizer, DiPricol Optix Gauges, #0 Fuel Plate, 14cm Non-Wastegated Housing, Amsoil 4510, T/C Lockup Switch, 15* Timing, 4" Turbo Back to 5" Mitres
12valveterror is offline   Reply With Quote
Old 07-28-2009, 01:06 PM   #3 (permalink)
P-pumped 24v Guy
mathews8pt's Avatar
I pulled mine one at a time, oiled it and retorqued to stock(about 100). I found the bolts on the exhaust side were all dry when i pulled them, the others were fine but i took each bolt out and oiled it just to be sure. After oiling i took them to 110, 115, 120 then 125ft lbs.
Was running about 47psi on it, now im up to 55 and havent had any problems....yet.
2000 QCSB with a p-pump, typically broke and always stealing $$ from me
ohiocoalrollers.com
mathews8pt is offline   Reply With Quote
Old 07-29-2009, 12:25 AM   #4 (permalink)
cool, thanks for the info guys
