1997 cummins 12 valve engine computer - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 07-14-2009, 05:15 PM Thread Starter
xm708's Avatar
Guys I am currently restoring a burned out 1997 3500 and was wondering are the manual computers interchangeable with the automatic ones ? my parts truck was a stick and my burnt one is an auto.
xm708 is offline
post #2 of 7 (permalink) Old 07-14-2009, 06:06 PM
ykdave's Avatar
No, the PCMs are different between the 2 since the PCM controlls some of the transmissions function (lockup/od).
As far as it getting the truck running, yes it will. The PCM only controls the charging and grid heaters as far as the engine goes (because of course its mechanical injection)
ykdave is offline
post #3 of 7 (permalink) Old 07-14-2009, 11:24 PM Thread Starter
xm708's Avatar
ecu
thanks for the reply that is what I thought just really needed a second opinion.
thanks
ed
xm708 is offline
post #4 of 7 (permalink) Old 07-14-2009, 11:47 PM
Stump Jumper's Avatar
If it was me I would try it and see if it worked I swaped to a manual and still have my auto comp and it works. With the only other things the comp controls is the charging and heaters I dont see why it would not work to run just those unless the wireing to the main comp plugs is differant.
It will definatly run just may not charge or heaters may not work.
97 12 valve HX40/HT60 Twins, 0 plate FF, 2095 plug, AFC tweaked , 4k gov, 16*, Weston's 5X.014s, 5in from turbo to stack, Twin Ram, HTT manifold SB 3250 DD Gauges up the wazoo.
Stump Jumper is offline
post #5 of 7 (permalink) Old 07-15-2009, 12:58 AM
calebmcclellan's Avatar
iTrader Score: -1 reviews
i think that the controllers themselves are the same, it's just the programming on them that are different. that's why they have to have the VIN programmed into them so that the correct software can be programmed into the controller
86 C/20 w/94 12v 420k miles
calebmcclellan is offline
post #6 of 7 (permalink) Old 07-15-2009, 01:06 AM
ykdave's Avatar
It probably wouldnt be too hard to have it sent out and 'reflashed' with the proper software. that is, if they are the same hardware internally.
It doesnt make sense that they would use 2 completely different PCMs just becuase one app requires a few extra basic functions. (it would probably cost them more money to use 2 different PCMs with different internals than what they would save for the electronic parts)
But ya never know, since when have any of the auto makers made any sense?
ykdave is offline
post #7 of 7 (permalink) Old 07-15-2009, 08:16 AM Thread Starter
xm708's Avatar
ecm
Well I was cleaning out under the hood last night. It is unbelievable you can't even tell what was what after a fire. It is just a big pile of melted junk. anyways the automatic computer is junk kinda toasted so the manula will go in to run the truck. I have leads on a 1997 auto computer the guy bought an engine with harness and computer and is only using the engine so I may have lucked out.
thanks guys
xm708 is offline
