transfer case concerns - Dodge Cummins Diesel Forum
Old 02-14-2007, 02:50 PM   #1 (permalink)
gstanfield's Avatar
Alright guys, I'm getting kinda scared here with this truck. My transfer case is hard to shift into 4HI from 2HI. With my superduty it took two fingers no matter if I was sitting still or doing 80mph. With this truck I have to pull hard and wiggle. Then shifting back into 2Hi is easy.
How hard shoudl it be to get from 2HI to 4HI? Is there a trick to it on these trucks? Should I do it stopped, moving, what?
I never noticed it at first, but with all the snow we've been getting I find I need 4wd a lot more, especially with the torque this thigns has.
Thanks for any ideas or suggestions,
George
1997 2500 ext cab long bed 4x4 Boost control elbow, BHAF, KDP tabbed, 3k gsk kit, dodgezilla hybrid turbo, Z-series gauges, 47RE built w/valve body & converter, #100 plate.
gstanfield is offline   Reply With Quote
Old 02-14-2007, 08:09 PM   #2 (permalink)
AlGores worst nightmare
Racer9's Avatar
Mine's hard to shift also. If rolling just hold pressure back and it will go in, if stopped it's easier in nuetral.
'96 2500, CTD, 4X4 flatbed, Isspro gauges, Skyjacker D-25's, ThurenFab track bar, DSS, HD steering.
Motor; BHAF, #100 fuel plate, 5X.012 90hp injectors, Pacbrake 4kGSK, Loose starwheel. 306hp/743tq before injectors.
Exhaust; Schwitzer S300G, 4" downpipe, single 5" turnout stack.
Trans; Dunrite VB/TC, Intelligent Engineering billet input shaft, Burt Brown rebuild/upgrade.
Racer9 is offline   Reply With Quote
Old 02-14-2007, 08:48 PM   #3 (permalink)
gstanfield's Avatar
OK, wasn't sure what it was going to feel like. I was used to the Ford unit.
Thanks,
George
Old 02-14-2007, 08:55 PM   #4 (permalink)
bow2no1
Guest
Posts: n/a
who makes the transfer case?
most transfer cases are made by new process..
some ford and dodge transfer cases are the same!
so yer not totally free and clear yet sorry..
it's easy to tell just go under yer truck and on the back side of the transfer case on top there should be a round tag.. on top there should be a number like 241 XXX or somthing like that
tag will look like this
Old 02-14-2007, 09:12 PM   #5 (permalink)
gstanfield's Avatar
Yeah, it's a NP. I realise that they are the T-case used in most applications these days. I wasn't sure if it had something to do with the front axle vacuum thingy, or somthing. I personally think it should slip into gear just as easy as my Ford did, maybe I can crawl underneath and see if there is something bound up with my linkages or something.
Thanks for the heads up though, I guess I sounded more ignorant than I really am (I promise)
Question for you Bow, how easy does your NP shift into 4HI? Is it a two finger operation, or does it take a hard tug, pull?
Thanks,
George
Old 02-14-2007, 09:41 PM   #6 (permalink)
bow2no1
Guest
Posts: n/a
it moved really hard when i 1st got it.. it still moves hard but not like it i did..
still "full fingered"
i havn't gotten arount to taking it apart and cleaning it.. but i did spray the heck out of it with PB blaster... it definetly hepled
Old 02-14-2007, 09:45 PM   #7 (permalink)
gstanfield's Avatar
I'll hose it down with some PB blaster and then dry it off and spray with some grease and see if that helps any. There have been a couple of times when I couldn't get it to shift, or didn't want to pull any harder for fear of breaking something. It probably hasn't ever been used or cleaned though as the previous owner just used the truck to pull his camper with and being a snowbird he didn't hang around the winter weather all that much.
George
Old 02-20-2007, 12:36 PM   #8 (permalink)
94cummins4x4's Avatar
if you want to see if its in the case or the linkages.. go underneath and pop the linkages off the t case if you can move the lever on the t case relativly easy (probably need pliers) then its not in the t-case.. in which case lube up the linkages.. if it is really hard to move the lever on the t-case without the linkages on then you might be in for some trouble... i have a 94 that the 4x4 was always put to good use and it shifts with ease... just like my last dakota.. three finger pull on the coldest of days.. i hope all works out well.
94 RCLB 4x4, Suckin air and shootin smoke...
94cummins4x4 is online now   Reply With Quote
Old 02-20-2007, 02:24 PM   #9 (permalink)
95dodgectd's Avatar
you can should have a shift on the fly transfercase so that means it is acceptable to be moving while shifting into 4hi but you have to do it going relatively slow like i belive its 30mph or under. and to take it out of 4hi put in 2hi then back up a little.
97: rclb totaled 9-4-10
95dodgectd is offline   Reply With Quote
Old 02-20-2007, 05:25 PM   #10 (permalink)
Ridemywideglide's Avatar
You can shift into and out of 4hi at any speed, but manual states your not "supposed" to operate in 4hi above 55.. Coincides with the speed limit at the time of manufacture IMO...
As for backing up, Fords had to do that (maybe still do ) as the auto hubs would stay locked, our trucks don't use locking hubs. There is no need to backup.. When your 4x4 indicator goes out, your axle is free once again.
1996 2500 CTD, Ext Cab SLT, Longbed 4x4, 260K, 5 spd, 4:10's, 4 inch lift, 315/75/16's, Max Spool 2, HTT 64/65/12, Smokem's 5x012's, No plate, Hacked AFC, Autolite EGT, Boost & Fuel Pressure guages. 2005 Wideglide, 98ci, 37g's, 10:1, race heads.
Ridemywideglide is offline   Reply With Quote
Old 02-26-2007, 09:39 PM   #11 (permalink)
dodgediesel59's Avatar
Another thing is the older trucks and some very heavy newer ones came with a new process 205 cast iron gear driven that is very hard to shift. It should be a 241 in there though if i remember right.
Robert
2001 2500 flat bed with dual 5" stacks, billet auto,P-pump, 191's, 4gsk, 0 plate garrett 3788R colt stage 2 cam, .084 lines 125 vp injectors at 280 bar
dodgediesel59 is offline   Reply With Quote
Old 02-27-2007, 07:14 PM   #12 (permalink)
i can shift it in or out at any speeds pretty easy and i have 230K
1997 2500, CTD, cc, lb, 4x4, banks powerpack(twin ram intake, big head wastegate, quick spool turbo, fuel plate) K&N intake, 4 in turbo back magna flow exhaust, 3k governor sring kit, starwheel turned up about half way, boost and egt gauges, 34 pounds of boost.
97bankspower is offline   Reply With Quote
