blew trans...uprgades?
i bought my truck 3 weeks ago and the trans let go. its not all that modified but i do plan on putting a #10 plate and doing some towing with a 30ft enclosed trailer. so my question is what upgrades should i do so i dont have to worry bout burning it up again? heres some history on this. i flew out to sac and drove it down to san diego. truck ran like crap so i did the normal service of valve adjust, fuel filter, serviced air filter(k&n), kdp fixed, front crank seal/timing cover reseal, replaced belt, slip f-plate/afc f-f, straight piped it, serviced both diffs, t-case, trans and adjusted bands(way out of adjustment), oil change, and couple minor stuff but my gas mileage dropped from 19 to about 15mpg. i figured since i messed with the i/p it was normal. i was about to do the valve body upgrade from transgo and found the front drum scored so i figured it was time to come down and explains the loss in mpg. it has a aftermarket t.c. but other than that i think its stock. any suggestions on while its out? i dont have enough money for a billet t.c. and im doing the work myself(ex diesel dodge tech). any advise would be greatly appreciated!
97' 4x4 12v(cali),vb/upgraded convertor/built o.d.,banks plate f/f,afc f/f, straight pipe,banks big head w/g,s/w clicked a bit,silencer ring MIA,drop in k&n, synthetic 75w90 all around,isspro egt,autometer trans temp/boost gauges Last edited by PVAUTO : 07-04-2009 at 02:43 PM. |
#2 (permalink) |
![]() Join Date: Mar 2009
converter is kinda the heart of the whole deal. stock ones barely stand a chance against a stock motor. they just turn too much of that torque to heat. heat is the enemy. lu clutch is pretty weak to begin with and after so many on and off cycles the whole front of the converter flexes weakening it more. I know the billet is expensive, but doing it again is also. Good valve body or kit yours properly and the trans should be set for a bit more power and some towing. beef up the band apply strut also. I cant emphasize enough the stock stamped steel converter will bite ya if ya mod/tow heavy tho.
Dog's truck:95 2wd ex, built auto, kdp tabbed, 3 disc billet converter,3.54 gears, 4gsk, bhaf, 0 plate, rack plug, 90hp injectors, 191 DV's, htt 62/71/14, timed @17*, 60# valve springs, head studs, 5" exhaust, gauges |
#4 (permalink) |
I broke to input shafts and two converters. shoulve bit the bullet the second time but hard headness was kicking in...Now I have triple disc billet,billet input,laminated flexplate,and so on..
#5 (permalink) |
thanks for the replies...where can i get a single disc w/billet cover? or is it even worth getting and just jump right in witha triple disc
97' 4x4 12v(cali),vb/upgraded convertor/built o.d.,banks plate f/f,afc f/f, straight pipe,banks big head w/g,s/w clicked a bit,silencer ring MIA,drop in k&n, synthetic 75w90 all around,isspro egt,autometer trans temp/boost gauges |
#6 (permalink) |
Get the triple disc, do it now and be done with it. You also need to do a valve body and a billet input. These are the best upgrades you can do to your trans
1995 Dodge 160 pump 4k springs, 181 DV`s, 0 plate, DDP stage 3 injectors, Jefferson State Diesel o-ringed and ported head ARP studs, Joel Gooch build trans with a Spec-Rite torque converter.Thanks to Jefferson State Diesel and riles |
#7 (permalink) |
im gonna be installing the transgo TFOD-DIESEL kit. who should i get the converter from? looking for best price and i've heard of flipping a retainer and being able to add another clutch disc and fiber but i dont know if its in the O.D. unit of not? anybody hear of this or done it? is a external cooler worth installing or is the factory cooler sufficiant? sorry for so many questions i just dont wanna keep pulling the tranny down
#8 (permalink) |
so i assembled the overdrive unit and got rid of the retainer and was able to add 3 more steels/fibers for a little extra holding power and gutted the check valve in the cooler line.
#10 (permalink) |
sorry i dont really have time to do side jobs right now im actually working on my truck during my lunch break and after work finishing up on building two off-road race cars you can bring it in the shop and i can discount it some but thats the best i can do right now my shop is located in alpine(san diego county) where you located?
