Hey I have a few Questions I hope I can get some help with!
Im looking at maybe buying a 1997 2500 with 201,xxx miles and i was hoping you guys could tell me so of the problems you have had with a similar truck. Thanks Matt |
#2 (permalink) |
Wisconsin Chapter President
![]() Join Date: Jan 2008
Killer Dowel Pin ABS and Brake lights will come on do a search on either and you will find all you need
Wisconsin Chapter Prez 97 Fiat 3500 Dually - 62/71/14 - 5x.012's - Rack Plug - AFC Mods - Ished Timing - Helix II - 5" Str8 Pipe - BHAF- No Plate - 4k GSK - 60# Springs - Auto to Manual Swap- Valair 500hp Clutch - 342,500 miles Soon to be SRW
#3 (permalink) |
dont forget the transmission and water pump, mine went out after i reach 230000
1996 dodge 3500 4x4 230k- single 6 inch stack, spectre intake, wastegate blocked, upgraded 5th gear, and train horns NEW Carter Lift Pump 1985 chevy k-10, 350 bored .90 over with 400k miles, 35's and lockers |
#4 (permalink) |
killer dowel pin track bar ball joints
1996 2500 ECLB, NV4500, 4x4, 4" redneck tb exhaust-5" tip, BD brake, ATS 3pc, #0 plate, 4K GSK, wastegate plugged, SouthBend, welded 5th gear, Isspro pyro&boost, leveled, Thuren track bar, AFC tweaked, BHAF, silencer ring?, 15%/5% tint, 285/75/16 MT ATZ |
#5 (permalink) |
These trucks are brutally hard on everything in the front end And like mentioned above, KDP, possibly trans (especially if the engine has been modded). If its 4wd you will definitely want to make sure that its working, the CAD in the front axle is pretty failure prone after this many years. Though its not a hugely expensive fix, its just something to work down the price if hes asking too much. How much is the truck going for?$?$
97 Ram 2500 / 5.9ctd /NV4500/241DHD Custom Intake Tube+ BHAF, Pump Tuning, Autometer Pyro and Boost gauges, Dual 4" stacks, 33x12.5 Mud terrains, posi-lok, One Hella sound system, tons more to come
#7 (permalink) |
I have been looking around for some answers for the dowel pin but i really have not been able to find to much. I was hoping some one could give me a straight answer about whats up with it and the best way to go about replacing it?
#8 (permalink) | |
Moderator
![]() Join Date: Nov 2005
It doesn't matter how many miles the engine has, the KDP can fall out at any time. Worse case scenario is it can cost you entire new engine.
Bill '95 2500 4wd auto '95 3500 5 speed heavy hauler Not stock |
#9 (permalink) |
holy chit, that truck had better be MINT, and then some, for that kind of money...
#10 (permalink) |
Hey Matt gettin ready to do the KDP sometime this week probably in my truck, if this is the same Matt Kelly i know then come on over n you can see what it is, pretty simple really.
-98 12v Quad Cab Long Bed 4x4 Goerends Tripple Disc Converter, Valve body, Billet Flex plate, Ground fuel plate, BHAF, Isspro Gauges... Basicly stock. |
