Vin # reprogram ???? - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 06-30-2009, 07:56 PM Thread Starter
I just replaced the pcm in my 98 12 valve with a used one, now the electrical problem is fixed but I have the abs, brake and seatbelt light on. The dealer says that they can't clear the lights becaus the vin # in the pcm and the vin # in my truck don't match. I have been told by a few mechanics that it can be done and it makes sense that it can because you can buy factory refurbs... anybody know who can program my PCM with my vin#?
ditchpicklefan is offline
post #2 of 18 (permalink) Old 07-01-2009, 01:56 PM
'98 is an oddball, the PCM has to be specific to that year or it won't work or be reprogrammed.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #3 of 18 (permalink) Old 07-05-2009, 01:59 AM Thread Starter
I have the right pcm for the truck, i just need to find someone who can program in the vin #
post #4 of 18 (permalink) Old 07-05-2009, 02:58 AM
ykdave's Avatar
the dealer should be able to reprogram the vin and milage into the new PCM... if any of their mechanics have a grain of sense...
ykdave is offline
post #5 of 18 (permalink) Old 07-13-2009, 12:18 PM Thread Starter
i've talked to a couple of dealers now and they all say that it can't be done....
post #6 of 18 (permalink) Old 07-13-2009, 08:32 PM
calebmcclellan's Avatar
iTrader Score: -1 reviews
I'm a tech at a dealership and if my grain of sense is right i think that once a VIN is programmed into a controller it can't be changed.
maybe try some aftermarket company that can completely wipe out the pcm and reprogram it i dunno
86 C/20 w/94 12v 420k miles
calebmcclellan is offline
post #7 of 18 (permalink) Old 07-13-2009, 08:33 PM
When I needed one programed the dealer said to take to Cummins.
Cummins NW said to take to the dealer.
So I finally took it to the dealer, they sent it out to Cummins NW and they actually did it.
It was even right but cost $90.
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
post #8 of 18 (permalink) Old 07-13-2009, 08:43 PM
ykdave's Avatar
last time i had read up on it, the chrysler DRBIII scan tool was able to reprogram the VIN#
ykdave is offline
post #9 of 18 (permalink) Old 07-13-2009, 08:56 PM
yeah the drb is able to program the vin but i think once its programmed into a controller it can't be changed. the only time we ever need to program the vin on any vehicle is when the controller is replaced. and obviously at a dealership we don't put in "junkyard" controllers. every car i've worked on the had a "junkyard" pcm had a code for vin mismatch.
post #10 of 18 (permalink) Old 07-13-2009, 09:00 PM
ykdave's Avatar
i know nothing of the DRB3, so maybe it is, or isnt possible to reprogram the vin without first somehow erasing it.
This is what i got off of the writeup i was reading before... The writeup is based on using a DRB3.
Important Note:
If the Powertrain Control Module has been changed and the correct VIN and mileage have not been programmed, a DTC will be set in the ABS, Air Bag and SKIM modules when equipped. In addition, if the vehicle is equipped with a Sentry Key Immobilizer Module (SKIM), Secret Key data must be updated to enable starting.
For ABS and Air Bag systems:
1. Enter correct VIN and Mileage in PCM.
2. Erase codes in ABS and Air Bag modules.
For SKIM Theft Alarm:
1. Connect the DRB to the data link connector.
2. Go to Engine, Misc. and place the SKIM in secured access mode, by using the appropriate PIN code for this vehicle.
3. Select Update the Secret Key data, data will be transferred from the SKIM to the PCM (This is required to allow the vehicle to start with the new PCM).
4. If three attempts are made to enter secured access mode using the incorrect PIN, secured access mode will be locked out for one hour. To exit this lock out mode, leave the ignition key in the Run/Start position for one hour. Ensure all accessories are turned off. Also monitor the ( battery state and connect a battery charger if necessary.
ykdave is offline
post #11 of 18 (permalink) Old 07-13-2009, 09:11 PM
what you are reading is the correct procedure when replacing a controller with a new one. I've been using the drb everyday for about 5 years and have programmed many VINs but i have never erased one and dont think that it's possible with the drb. i'm sure its definitely possible to do with some other type of computer but i don't think that when chrysler made the drb they probably didnt want all the dealerships to go around erasing VIN #s. also i havent seen any 12 valve trucks with a skim module (key with a chip) so you dont have to worry about that.
post #12 of 18 (permalink) Old 07-13-2009, 09:23 PM
ykdave's Avatar
True enough, it may be able to change the vin, but im sure if it is it would be a real roundabout way to do it because like you say, im sure they dont want any ol monkey going around changing vin#s!
Maybe just try a place that reman's the PCMs, surely they would be able to set the VIN#
ykdave is offline
