Dreaded Ball Joint Replacement...What's needed? - Dodge Cummins Diesel Forum
Old 05-01-2009, 08:52 AM   #1 (permalink)
I've read a few tech articles, none specifically for my truck
I've got a 95 12v 4x4 2500 5 speed.
Needs at least ball joints (wheel play, tears wearing weird), bumpy going down the freeway off throttle.
Anyway, I'm going with moog upper and lower ball joints, I know I need to buy a press, what else? (check brakes while i'm in there, tie rods, etc)
1slowhatch is offline   Reply With Quote
Old 05-01-2009, 11:04 AM   #2 (permalink)
Chevy-Eater's Avatar
Check your wheel bearings too. If theres any hint of play found they need to be replaced. Be sure you have a good impact gun and a decent size air compressor for pressing your balljoints in and out. A good sized hammer and some WD-40 is always a good thing to have when doing this job.
Broken left wing......
Chevy-Eater is offline   Reply With Quote
Old 05-01-2009, 11:09 AM   #3 (permalink)
Hayhauler's Avatar
Did mine yersterday What a B*****!!!! good luck And dont for get smile.
Hayhauler is offline   Reply With Quote
Old 05-01-2009, 11:17 AM   #4 (permalink)
Deputy Diesel's Avatar
check the track bar and steering joints first they could cause these problems. to make sure its the ball joints jack the front end up, grab the tire at the top and bottom then lift and see it there is any movement up and down. make sure that if you replace the ball joints that you replace them with grease able ones and keep them greased they will last a long time. good luck!
1954 Dodge M43 D60, Sterling, built 360, 4 speed, 40 inch militaries. 1989 250 non ic 5 speed 4x4 35's timing gov spring, extensive tuning, high milage. 03 f350 7.3, 6speed, dually, 35's, dp tuner, Super GTP, south bend clutch, terminator t500, RR
Deputy Diesel is offline   Reply With Quote
Old 05-01-2009, 12:09 PM   #5 (permalink)
moparguy55's Avatar
iTrader Score: -1 reviews
another goog b joint ck is too lift up the tire and place a long pry bar under the wheell from the front of the truck.put some upwards pressue on the tire and move side to side and watch the b joints for movement.
01 2500 QCSB 4x4 6 speed stock,99 QCLB 4x4 auto
91 mustang LX Coupe HCI
70 charger R/T(in restoration)
moparguy55 is offline   Reply With Quote
Old 05-01-2009, 04:50 PM   #6 (permalink)
this is where i started... Ram Modifications
working on mine now use these moog part numbers in summit search bar... cheaper than o'reily's and car quest.
here is what ive collected from various places:
Below is just about every possible cause of sloppy steering, and alot of it applies to "death wobble" also, altough DW is really an alignment issue some of this can aggrivate it. Go through all of this and your Ram should drive better than new.
1. Ball joints: Jack truck up to get front tires off the ground, grab the tire on the top and bottom by hand and push and pull (do it hard enough to where the tire flexes a little). If you can feel any movement in the ball joints they are bad, you'll know when you feel it. For replacement get good quality (moog or similar). If your good at keeping up on lubing zerks then get greasable ones if not get sealed they will last longer if your bad a remembering to grease them.
2. Tie rods: While the front is jacked get inside the truck and lock the steering column, then get back out and grab the tire on the front and back (3:00 / 9:00 positions), push and pull here just enough so that if the steering wasn't locked you would be turning the tires. If you can feel any "play" (again you'll know it when you find it) then a tie rod end is bad, keep doing this while a helper looks at all the tie rod joints to see which ones have the "play" in them. For replacments on these just get good quality ones (moog or similar)
3. Track bar: Set the truck back on the ground and have your helper get in the truck and turn the key on, but don't start the truck. Have them move the steering wheel side to side from where the wheel gets stiff one way to where it get stiff the other way (enough to almost start turning the tires). While they are doing this crawl under the truck and look at the upper track bar joint where it bolts to the frame. If you can see the joint move (look close it will only be about 1/8th to a 1/4 inch) if the ball socket it self moves at all, right where it bolts to the frame it is bad. Fixes for this include, Luke's Link , Lindstad track-bar adjustable-end repair kit for 4x4's correcting steering problems for a fraction of the price. , Solid Steel.biz , Thuren Fabrication-products , DT PRODUCTS , or a factory type replacement. I highly recomend staying away from the last one though because it will just keep wearing out every 10k-20k miles.
4. Steering gearbox: Have helper continue to "saw" the steering wheel. Lay down under the front bumper and look at the front of the steering gearbox, watch closely at the sector shaft and pitman arm (sector shaft is the splined shaft that goes vertically up into the gearbox and is what the pitman arm connects to). what your looking for is the sector shaft to "rock" side to side within the gearbox. If any movement is found then the sector shaft bearings are worn. If the box is not leaking it might be able to be saved for awhile with a DSS Solid Steel.biz , as for replacments my first choice is cPanel®, next would be Welcome to AGR Perfomance, Inc. , and last would be a reman from an auto parts store.
5. Steering column: reach under the hool and grab the lower steering column (where the long black sring is) Push and pull (sideways in relation to the column), if any play is found the lower column bushins is bad. Only way to fix this is to replace the column with a new junk dodge one or to buy or make one of these 'Rock Solid' Ram Truck Steering !
6. Intermediat shaft: (shaft from the column to steering gearbox) Grab on to the shaft at the slip joint and push and pull (just like the column test) any play and its bad also watch the u-joint on this shaft for play while testing. For this there is several option, stock dodge replacment, borgesson shaft, flaming river replacement, or a stainless one from PSC cPanel®
7. Alignment: If everything above is good, steering is tight and a truck still wanders, then its probably in need of a "good" alignment because the caster is pulling one way while the camber is pulling the other way. Here is a link to some info on aligning the dodge ram Ram steering specs . Print it out and take it with you anytime you get an alignment, have them set it to those specs and ask for a print out after they are done so you know they did it correct.
Ram Modifications
Long tie rod: DS1456 -$153.95 summit $260.52 william car quest
Drag link: DS1459 -$65 car quest matched oreilys
Left tie rod end: ES3496 -$61.95 summit $78.48 william car quest
Drag link tie rod end: ES3497 -$63 car quest matched oreilys
Small adjusting sleeve: ES2012S -$27.95 summit $35.39 william car quest
Large adjusting sleeve: ES3498S -$53.95 summit $68.78 william car quest
$425.80
Pricing and ordering
DSS(STEERING STABALIZER) $169.00
03 TD TRACK BAR ADAPTER BRACKET -$159.00
SSSSS -
$145.00 TRACKBAR ADAPTER
DT PRO FAB
DSS- $175
TRACK BAR- $395.00
LUKE'S LINK - $69 EACH OR 4 OR MORE $58 EACH
1997 CTD2500 "CASPER"
PHILIPPIANS 4:13
GOLDDUSTERS5703 is offline   Reply With Quote
Old 05-24-2009, 02:33 AM   #7 (permalink)
Just added the cross-over steering using parts from this thread. Works well.
'96 12V 4WD with NV4500, Gauges, H2 Wheels, etc.
halbritt is offline   Reply With Quote
