Originally Posted by SOUTHERN SMOKE
different flange, different downpipe, and the anglelution to the intercooler boot from the turbo is different, and it also has an electric wastegate, it has been done before, but is a pita to do... look on here in the search section, you should be able to find the write up on it...
and after you do all that you can pull it off and replace it with a modified hx35. way more practical and probably cheeper.
1954 Dodge M43 D60, Sterling, built 360, 4 speed, 40 inch militaries. 1989 250 non ic 5 speed 4x4 35's timing gov spring, extensive tuning, high milage. 03 f350 7.3, 6speed, dually, 35's, dp tuner, Super GTP, south bend clutch, terminator t500, RR
