Can I Make A Homemade Torque Converter Lock Up Switch For My 1994?? And How? - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 03-13-2009, 01:30 PM Thread Starter
12vredneck's Avatar
I got a 1994 Dodge Ram 2500 12Valve 4x4. I got a automatic transmisson and been wondering about this torque converter lock up switch. My buddy had a homemade one on his 1995 and it came in handy. So i was wondering if you can do a homemade torque converter lock-up switch to my 1994, and if so how do I make and install it??
I'd Really appreciate your input guys
Thank You,
Jeff
1994 2500 Dodge Ram 2500 RCLB TOY "Billet Steel With Sex Appeal" Big thanks to Preble Diesel Performance, Hamilton Performance, Goerend, ETC..
12vredneck is offline
post #2 of 11 (permalink) Old 03-13-2009, 05:32 PM
12valveterror's Avatar
iTrader Score: 9 reviews
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
make sure you read the directions for the 94-95
and there is a possibility that your trans may go into "limp mode" all that is needed is for you to go to the dealer to get the computer reflashed.
Engine: Mahle "Marine" Pistons, Balanced Rotating Assembly, ECD Cam, O-Ringed Block, Ported/O-Ringed Head, 3 Angle Valve Job, ATI SuperDamper
Fuel/Air: 475cc P-Pump, 5x.014's, Airdog 150, BW 66/68/14
12valveterror is offline
post #3 of 11 (permalink) Old 03-13-2009, 10:43 PM Thread Starter
12vredneck's Avatar
how do i know if it limps??
post #4 of 11 (permalink) Old 03-14-2009, 08:14 AM
The '94 and '95 don't have a limp mode. Hydraulic governor instead of electronic so there is no way to make it limp.
KDP tab fix info and fuel system article
'95 2500 CC auto 4X4, 3.54, EGT, boost, fuel pressure, trans temp guages, PacBrake, TST #5, DTT VB, DTT triple disk TC, DTT billet flex plate, Cummins chrome kit.
Joe G. is offline
post #5 of 11 (permalink) Old 03-14-2009, 11:13 AM
Dwayne's Avatar
What about a 97?
Dwayne is offline
post #6 of 11 (permalink) Old 03-14-2009, 11:16 AM
I don't think a 47RE in a '97has one either, but you need to make sure by asking someone else to make sure.
Joe G. is offline
post #7 of 11 (permalink) Old 03-14-2009, 12:56 PM
hoodstack96's Avatar
With your 47re tranny Joe G. you need to remove the transmission control relay and instal a jumper wire between two of the termianls. I can check and see which ones I had, but I have heard that on some of the 96-97re's you need to have the pcm re-flashed. I was fortunate enough not to have that done. And you will know when the tranny goes limp. My friends did and it seemed to take off and stay in second only.
1996 2500 4x4, Externally Gated HX35+HT60,#100, 3000 GSK, 18*, DDP 191's,5x.014's, Modified AFC,5" Hood Stack, Home Made Traction Bars,Autometer Ultra Lite II Gauges,Auto to Manual,Valair 12 1/4" 3800# Ceramic, 3.54:1 Gears.
hoodstack96 is offline
post #8 of 11 (permalink) Old 03-14-2009, 12:58 PM
thats the link. thanks 12valveterror
post #9 of 11 (permalink) Old 03-14-2009, 07:51 PM
my bad its between 9-95 - 4-96 they used some computer program that dont allow it to lock up
post #10 of 11 (permalink) Old 03-15-2009, 01:07 PM Thread Starter
12vredneck's Avatar
YA MY STUPID SELF JUST INSTALLED IT AND PROBLEY MISSUSED IT NOW I GOT A STEADY STREAM OF TRANSMISSON FLUID COMING FROM THE INSPECTION PLATE ON THE TRANNY. I DONT KNOW WHERE OR WHAT IS CAUSING IT TO?
post #11 of 11 (permalink) Old 03-20-2009, 12:10 PM
I had that too, it was coming from the heat exchanger, once I climbed under and looked around, I could see it was coming from up higher than it looked.
Mine: 97 2500-2wd-Auto-Loaded-5" Exhaust, KN Intake, turned up IP.
#2: 1997 2500-4wd-5spd-Loaded-4" exhaust-KN air filter-turned up IP
thejunkman2005 is offline
