đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Good morning everyone! I have a 1998 12 valve with a 47RE transmission. I’m looking to do a G56 swap but have been struggling to find what I need to do with the wiring to bypass the neutral safety switch to start the tuck. If possible I would like to eliminate any check engine lights and would...1 reply 112 views
I know it’s been asked a million times but I’d like to hear opinions on exhaust housing sizing Truck is an 01’ 6 speed. I’m going to be dropping it off at industrial injection in about a month for a built/balanced motor ported head, p7100 swap and compounds. Timing will probably be around 24°...2 replies 82 views
Hoping someone can guide me in the right direction to this issue. I have an 09 6.7 with the 68rfe transmission. Purchased the truck about 5 months ago first day I got it randomly shifted into 4th from 6th gear. Thought it was just a fluke thing until about a month ago it happened again. Since...0 replies 20 views
Howdy folks it’s been a while since I’ve posted, I’m curious how much should a transmission rebuild cost in 2024, as well as having a transfer case resealed. I’m out west here in the pnw specifically Oregon.14 replies 246 views
Hey guys, this is my first post so hopefully I'm approaching this right. Today I took my (new to me) truck through an automatic car wash (probably my first mistake) and the check engine light turned on in the middle of it. I'm assuming the undercarriage wash hit something and caused all these...3 replies 98 views
