48re mate to a 12v? - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 03-02-2009, 10:48 AM Thread Starter
hjpcummins's Avatar
48re mate to a 12v?
i have been checking out the possability of mating my 06 48re to my 12v. with a plate from destroked.
and their final words were it will mate up.without a plate. meaning ther bolt patters are the same. besides the comp.what else would be needed?
97 12v 3500.....terd
hjpcummins is offline
post #2 of 19 (permalink) Old 03-02-2009, 12:37 PM
AlGores worst nightmare
Racer9's Avatar
If you swap valve bodies, so the wiring matches up, you can use the 12v computer.
'96 2500, CTD, 4X4 flatbed, Isspro gauges, Skyjacker D-25's, ThurenFab track bar, DSS, HD steering.
Motor; BHAF, #100 fuel plate, 5X.012 90hp injectors, Pacbrake 4kGSK, Loose starwheel. 306hp/743tq before injectors.
Exhaust; Schwitzer S300G, 4" downpipe, single 5" turnout stack.
Trans; Dunrite VB/TC, Intelligent Engineering billet input shaft, Burt Brown rebuild/upgrade.
Racer9 is offline
post #3 of 19 (permalink) Old 03-02-2009, 05:28 PM Thread Starter
hjpcummins's Avatar
i thought the 47 was pure mechanical?
no computer?
so i will bolt right up?
post #4 of 19 (permalink) Old 03-02-2009, 05:31 PM
the 47RH is mechanical and the 47RE is electronic....
94-SCLB-WOP Triple Turbo-810hp-
straight_six is offline
post #5 of 19 (permalink) Old 03-02-2009, 05:32 PM
what # fuel plate would be the best for delivering the most smoke
john jr is offline
post #6 of 19 (permalink) Old 03-02-2009, 05:32 PM
SilverBack76's Avatar
Didn't Garmon do this last year?
Fueled by PPE, F1, Smarty, Spooled by HTT, Odds and Ends from Opie, and all put to the ground by GARMON and the Boys at DogHouse Diesel!
Common Sense is so damn rare it should be a Superpower.
SilverBack76 is offline
post #7 of 19 (permalink) Old 03-02-2009, 05:33 PM
post #8 of 19 (permalink) Old 03-02-2009, 06:13 PM Thread Starter
hjpcummins's Avatar
correct me if wrong? 94' =47re?
by the way i didnt know fuel plates deliver smoke? does it fedex or ups?
post #9 of 19 (permalink) Old 03-02-2009, 06:49 PM
94 is a 47RH
post #10 of 19 (permalink) Old 03-02-2009, 07:48 PM
ups, actally what i ment was what# fuel plate will make the most smoke considering it adds more fuel
john jr is offline
post #11 of 19 (permalink) Old 03-02-2009, 07:51 PM
gl155man's Avatar
yes
04.5
gl155man is offline
post #12 of 19 (permalink) Old 03-03-2009, 06:45 AM
The 47RH is Hydraulic (that is mechanical) ('94 - '95). The 47RE is Electronic. ('96 and later). The PCM (computer) is different for the RH than the RE because of that. The transmission for the RH is longer because there is a fly weight governor in the tail shaft. Anyway, there are more problems installing it a '94 than a '96 or later.
KDP tab fix info and fuel system article
'95 2500 CC auto 4X4, 3.54, EGT, boost, fuel pressure, trans temp guages, PacBrake, TST #5, DTT VB, DTT triple disk TC, DTT billet flex plate, Cummins chrome kit.
Joe G. is offline
