Old 03-01-2009, 11:04 PM   #13 (permalink)
13 lol shoot ya it will probly bring it up 1 or 2
5.9L CUMMINS 2nd gen.- 5 sp,2.5in kit leveled by kore, adrenalinechip,SBC DAUL DISK 3250,BHAF,outerwear,Custom lime green intake manifold, FASS 150,4in straight pipe 6in tip silencer ring MIA
DJ parris is offline   Reply With Quote
Old 03-01-2009, 11:06 PM   #14 (permalink)
ykdave's Avatar
wow, 13mpg, thats brutal!
I havent really paid alot of attention to my mpg but after putting on my 33" tires and at about the same time i put on the BHAF and my milage seems to be about the same on the highway (mid 20s) so i expect that it did help a bit.
You can get the filter pretty much anywhere the 2790 wix/napa also crosses over to a few other MFGs so you shouldnt have a problem getting one.
97 Ram 2500 / 5.9ctd /NV4500/241DHD Custom Intake Tube+ BHAF, Pump Tuning, Autometer Pyro and Boost gauges, Dual 4" stacks, posi-lok, One Hella sound system, KDP MIA , fabtech 5.5" lift, 36x13.5 IROK's, tons more to come
ykdave is offline   Reply With Quote
Old 03-01-2009, 11:07 PM   #15 (permalink)
9812v5spd's Avatar
ykdave thats a bad@@s intake setup. what would you use for a heat sheild?
-1998 12v, nv4500, SBC Con OFE, SBC 1 3/8"input shaft, #100 fuel plate,15*timing,bhaf,5" straight pipe,8" long arm lift,385/70 mud grapplers(as tall as any 38),autometer pyro/boost,6000k HID's-
9812v5spd is offline   Reply With Quote
Old 03-01-2009, 11:11 PM   #16 (permalink)
ykdave's Avatar
their are plans kicking around for a BHAF heat shield somewhere on the boards. You can use whatever you got kicking around, tin or light gauge sheet metal
Old 03-01-2009, 11:14 PM   #17 (permalink)
they also sell them online somewhere if i remember i just heard it ant much of a big deal to have a shield
Old 03-01-2009, 11:25 PM   #18 (permalink)
ykdave's Avatar
not having the heatsheild isnt going to kill you, but it does kind of defeat the purpose of modding the intake when you go from a low flow cold air (stock) setup to a higher flow filter thats sucking in smoking hot air!
Old 03-01-2009, 11:37 PM   #19 (permalink)
9812v5spd's Avatar
where can i find an outerwear pre filter for that 2790? im seriously guna go buy one tomorow.
Old 03-04-2009, 06:07 PM   #20 (permalink)
for the aftermarket cold air intakes, I would say S&B filters are the best bang for your buck. Its like $269 shipped from most places. But then again you can't beat the price of a bhaf. their website is sbfilters.com
97 2500 ext cab longbed 4x4 ctd
never2fast is offline   Reply With Quote
Old 03-04-2009, 09:10 PM   #21 (permalink)
air intake
I just put a Summit cold air intake on my 94. Its the exact same thing as K&N but about a $100 bucks cheaper. It even has all the same K&N logos on it even though it doesn't show them in the pics on their website. I think the K&N was around 280 and the Summit was around 180. You can really hear the turbo now. Had a friend open the glove box Monday because he thought I relocated the filter in there.
bluetj00 is offline   Reply With Quote
Old 03-05-2009, 01:11 PM   #22 (permalink)
Super Moderator
If you want the best bang for the buck try this one, beats a BHAF hands down and
only cost me $2>>> Modify Stock Airbox???
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Not stock
Old 03-05-2009, 02:40 PM   #23 (permalink)
9812v5spd's Avatar
i want a pre filter
Old 03-05-2009, 02:46 PM   #24 (permalink)
MOPAR MAN's Avatar
S&B makes a good intake
00 2500 4x4 5spd, Balanced & blueprinted, Rings&Studs CR Head W/P&P, All ARP, HD Big Stick, 110# Valve springs, Coated pistons & bearings, S&B, Intake horn, Header, 5" TB, Edge J W/A HOT, GT3788R, 120HP stix, FASS, ValAir DD, Fluidamper.
MOPAR MAN is offline   Reply With Quote
