đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Hello, I have a 03 3500 5.9l with a 48re transmission. I recently purchased a Launch x431 torque link and it isn't able to communicate with the TCM. Also purchased a Obd2 breakout box. There is no driving issues but I do have a P0700 code, issues with fuel economy, or low transmission fluid...4 replies 70 views
Trying to fine-tune my alignment now that I’m on my new tires, stock 265/70/17. it feels like it kind of wanders at high speeds. I’ve got some angle iron I’m gonna make brackets to do good measurements, I’ll take the front wheels off and bolt the brackets to the hubs. Should I do zero, dead...4 replies 119 views
I'm thinking of looking for a decent flatbed to put on my 97 2500 SRW. When looking at a used one, without knowing what truck it came off of, how can I know if it will bolt on to my truck? Thanks for any advice you could throw at me.0 replies 0 views
I would of liked to go with an HP tuner, get a rail gauge; pay for dyno time - but I didnt; I bought a locked s06 and paid $150 to unlock it. Things I have learned: Revo low-mid levels are the best mpg choices. TNT is strong ; but harder on the rail, cp3 demand, and mpg suffers even on sw1...3 replies 119 views
