I did the conversion this past winter. It's not hard at all. You'll need to get your drive shaft customized. The 2wd nv4500 is 6 inches shorter than the 47re. The driveshaft from a manual truck won't work unless you swap the d70 for a d80.
If you have everything from flywheel to rear axle then that's good.
