👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
I’ve perused the forum for an answer. My issue the cruise works, the lights come on when I start it. The 20a fuse is fine. The relay is not clicking, I replaced with another relay and still no dice. I don’t think it’s the clock spring, I haven’t pulled the airbag to see if the horn wires are...1 reply 68 views
My head hurts from trying to find a simple explanation regarding Diesel Fuel and the different types. Living in California (blech) I'm seeing more and more gas stations with diesel pumps that have Biodiesel and different numbers. What's it all mean Mr. Wizard? I thought I had to run Diesel #2...67 replies 2K views
Hey guys, this is my first post so hopefully I'm approaching this right. Today I took my (new to me) truck through an automatic car wash (probably my first mistake) and the check engine light turned on in the middle of it. I'm assuming the undercarriage wash hit something and caused all these...4 replies 108 views
Thought I asked this, but maybe not here... Having a converter done tomorrow (local shop, cut, rebuild, upgrade). I have the option to go low stall (1600ish rpm) for added $. For a basically stock engine with a few free power mods, and the 727 (which is going to be redone also), does 1600 rpm...1 reply 73 views
