đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
I am getting a message exhaust filter full power reduced see dealer 5 days ago Feb 25, 1024 Message exhaust filter 80 full safely drive at highway speeds to remedy Then after driving another message exhaust system regeneration in process exhaust filter 80% full Then it dropped to 70%...10 replies 461 views
My truck was a factory Auto swapped to 5 speed trans. So I have found some auto trans remnants, but I don't know if this is one or what it is? Anyone know? 1 pic shows where hoses connect to the other shows the ends that were cut off.2 replies 132 views
I've seen a few older threads debating the maximum lift pump fuel pressure the cp3 can take on the 3rd gen and newer trucks. I wanted to ask the question and get new info. I've seen it claimed the stock cp3 can handle up to 100 psi of lift pressure how true is this? If that is so why do we see...11 replies 379 views
