đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Hey guys so I’m new to the 5.9’s, found one up for sale with 90k miles and had to have it. So I did all of the basic maintenance, air filter, oil change, transmission change. Well it’s now two days after the oil change and I decide to take the truck to work, when I got to work I noticed right...5 replies 143 views
I have a 1995, dodge 3500 12 valve I assume it has the 47 rh transmission I have posted pictures before of some sensors or wires that are not connected to the truck original I have replaced the turbo with the K 27 rebuilt the transmission and installed cages for boost EGT and transmission before...9 replies 132 views
Hey guys. Just bought my 06 2500 Mega Cab 6sp about a month ago. I've posted about it twice already, but I can tell I will be doing a ton to this thing. Most likely I'll need all the help I can get. Rather than post a bunch of individual threads I will have all my progress and questions here...103 replies 6K views
Trying to fine-tune my alignment now that I’m on my new tires, stock 265/70/17. it feels like it kind of wanders at high speeds. I’ve got some angle iron I’m gonna make brackets to do good measurements, I’ll take the front wheels off and bolt the brackets to the hubs. Should I do zero, dead...5 replies 127 views
