👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Hello to all. New account so bare with me . I have a 2003 Dodge Ram 2500 5.9l Cummins. I was wondering if i’d be able to pass smog straight piping the exhaust? I pass smog normally but want to go ahead and straight pipe. I know there’s no o2 sensors on the systems so there should be no problem...20 replies 385 views
Howdy folks, Can anyone get me started with a baseline rear caster setting on my truck? It's a 2018 2500 4X4 with a 4" lift. Looking at the position of the bolts, something is definitely off here. Rear passenger side of the truck sags an inch or two. With the steering wheel centered, the...8 replies 177 views
Recently been having some trouble with my transmission, but specifically the torque converter I think. When driving home under light throttle, my trans will lock the converter around 45mph and begin to shutter and buck unless I speed up. Any ideas on what it could be? Slipping converter maybe?0 replies 3 views
I have a 1995, dodge 3500 12 valve I assume it has the 47 rh transmission I have posted pictures before of some sensors or wires that are not connected to the truck original I have replaced the turbo with the K 27 rebuilt the transmission and installed cages for boost EGT and transmission before...10 replies 137 views
