This 96 cummins with 325k miles burns 1 quart of oil every oil change is this normal and would buying a truck like this scare you guy did come down to 4500 and it does have a suncoast transmission and a few mods + it needs body work aka rust not bad tho
I didn't look at it yet cause its far he said it doesn't leak just that every oil change intervals it burns a quart of oil and I guess there's no blow by and it passes a compression test how do you check blow by?
Well I just like to have second opinions specially from people that are more experienced with these trucks then I am its a bit rusty around the edges but i can fix that I just dont want to rebuild the engine cause I need a daily driver
If you drive it 15,000 miles a year the engine will not need a rebuild in 20 years if you take care of it. It is the uneducated that use less than adequate air filters, cheap oil filters, dump weird stuff into the fuel tank and let minor problems become major problems that have to rebuild their engines before 600k.
Don't let that be a deciding factor, just a piece of paper. Plenty of "certified" techs don't know there elbow from their ..well you know.
I wouldn't be surprised if most of the loss was from leaks.
What part of the country you in? Might be able to haggle that down a little more considering the mileage and body condition..is it just rust or is it rotted through?
That's a lot of rot showing, how much is hidden? What do the floors under the truck look like? If they are in good shape it might be worth it. Even in the rust belt, that seems a little high of a price for the mileage and condition. I'd be looking at closer to $3000/$3500 range, personally.
Boy, I would pass!!
I live in Oregon, so little rust issues...Trucks here are 5k and up...
I posted this earlier just cause it had a moon roof that looks stock, but an example of a similar truck...cheaper to buy a plane ticket I would think 1995 Dodge Ram Diesel Club Cab 4x4
Haha I agree well Im just going to save up a little more money people on the classifieds want there truck weight in gold what do they think my pocket is fort knocks
