đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Good morning, i recently bougt a '97 2500 12V Cummins 4x4. When I bougt it transmission was not shifting to OD. I did the way back home though in 3rd with 3000rpm about 600km. At the end it once shifted in OD but never again. So I dismounted engine and transmission and give it to someone who...0 replies 0 views
Need advice on the best places to get an engine used or reman. 2006 6sp manual. My son turned 16 today. He bought the pickup from a dishonest party. When we started it cold, it was missing. Today I pulled the #1 injector and it had metal pieces all over the tip. He spent every penny he had, now...21 replies 391 views
I'm thinking of looking for a decent flatbed to put on my 97 2500 SRW. When looking at a used one, without knowing what truck it came off of, how can I know if it will bolt on to my truck? Thanks for any advice you could throw at me.2 replies 74 views
Good morning everyone! I have a 1998 12 valve with a 47RE transmission. I’m looking to do a G56 swap but have been struggling to find what I need to do with the wiring to bypass the neutral safety switch to start the tuck. If possible I would like to eliminate any check engine lights and would...1 reply 112 views
I know it’s been asked a million times but I’d like to hear opinions on exhaust housing sizing Truck is an 01’ 6 speed. I’m going to be dropping it off at industrial injection in about a month for a built/balanced motor ported head, p7100 swap and compounds. Timing will probably be around 24°...2 replies 82 views
