fuel shutoff solinoid - Dodge Cummins Diesel Forum
Old 02-03-2009, 12:43 AM   #1 (permalink)
cosmo22nov's Avatar
well every time i start my truck i have to pull the lever on the fuel shutoff up to start my truck. i tried replacing the relay and that wasnt it. so whats wrong?
thanks,
tanner
95 single cab short bed 1/4 mile- 13.3 @ 104mph Sold
94 single cab long bed- mostly stock
cosmo22nov is offline   Reply With Quote
Old 02-03-2009, 01:15 AM   #2 (permalink)
ykdave's Avatar
Have you tested for power going from the relay to the solenoids pull coil? If their is the solenoid is junk.
If not, check for ground and power to the relay. it should have a constant power and another line that is hot while the starter is energised
2007 Laramie 3500, 4.5" RevTek, 35x12.5 ProComp MTRs, buckstop front+rear, bullydog TD, BD RFI intake, Lightforce 140s in the bumper, 240HIDs up top
1997 SLT 2500, 5.5" fabtech, 36x13.5 IROKs, 5x12s, s300, 4kgsk, inj pump FUBAR
ykdave is offline   Reply With Quote
Old 02-03-2009, 10:17 AM   #3 (permalink)
Check the dark blue wire on the positive post of the driver side battery.
KDP tab fix info and fuel system article jgeorge1@suddenlink.net '95 2500 CC auto 4X4, 3.54, EGT, boost, fuel pressure, trans temp guages, PacBrake, TST #5, DTT VB, DTT triple disk TC, DTT billet flex plate, Cummins chrome kit.
Joe G. is offline   Reply With Quote
Old 02-03-2009, 10:32 AM   #4 (permalink)
cosmo22nov's Avatar
actually i have a buddy with a 12v, could i take his shutoff solinoid and put it on my truck to see if mine is bad?
Old 02-03-2009, 10:59 AM   #5 (permalink)
Super Moderator
First check the blue wire as Joe said.
It's the problem at least 75% of the time.
It may be corroded under the insulation where you can't see it.
If you need to test your solenoid it's much easier to unplug it and jump a negative and positive from the battery to it than to swap with another truck.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
Old 02-03-2009, 08:37 PM   #6 (permalink)
you could always put a hand kill like i did on mine. Previous owner went through three solinods.
1994 dodge 2500 4x4 12v. no engine mods yet. The tranny has been built and a aftermarket convertor. Small lift on 35'. 5'' exhaust and cold air.
asphcowboy is offline   Reply With Quote
