Like the subject says, after idling for a time, warm engine, I have twice now heard a hissing sound (vs the normal deep throated locomotive-like sound) at the tailpipe. Any ideas what that might be?
The Machine: White 1997 3500 DRW, 5sp, 4x4, ExtCab, SLT, KDP'd, Exhaust Brake, Pyrometer, BHAF, Howes additive! Good for now..
Now that we've heard from the peanut gallery (seemingly a necessity..) perhaps we can get some technically-oriented comment or idea of what could be producing such a noise.
Thx.
No, I believe that (e-brake) is a gentle sound from the engine compartment. This is a sound of air discharge over the sound of the exhaust, loudest at the tailpipe and it stops with a bit of a touch on the accelerator as far as I can tell.
Next time it happens I'm going to take a video of it so I can post the sound.
How long of an idle are you talking about?
Extended idling is bad for these engines, Cummins says no more than 5 minutes.
If cylinder temps are too low unburnt fuel washes the lubricating oil off your cylinder walls, compression escapes past the rings.
Maybe that's what you're hearing, along with the destruction of your engine.
__________________ Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
Thanks for all the ideas so far. As promised, I have two videos, one with the way it usually sounds, it's longer because I like the sound. The other displays the non-standard sound. Hope it helps to get some idea of what it is and possibly how to fix or avoid it.
Good:
Not-So-Good:
hmmmmm, my dads 91 did that ALL THE TIME, it turned out to be a pin-hole in the turbo housing... that is strange it doesn't do it all the time... good luck.
2K6 mega cab, 6 spd handshaker, areoturbine, Smarty jr, 17x10 Incubus off road 511's, 35x12.50 Yoko's SAC #257 DTR MEGACAB CLUB #207
