Transfer Case NP241 service manual found...here it is - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 12-28-2008, 12:51 PM Thread Starter
ve7kilohertz's Avatar
Hi Guys,
After 2 days of searching for some info on my NP241 transfer case, I am pleased to share with you what I have found. The factory service manual!
My transfer case has the dreaded chang, chang chang sound, skipping around jumping in and out of 4x4 and making terrible ganashing sounds. I spoke with a friend of mine who has been a mechanic for over 30 years and has worked on many t-cases (and who called this 241 a "cheese box" he can't believe Dodge put this behind a Cummins) and he has seen this symptom plenty of times. 7 out of 10 times he says it's the nylon pads on the shift forks that are worn out, and not fully engaging the sprocket on the shaft. With fingers crossed, it hasn't worn into the gears or worn the shift fork and changing the pads should get me going again.
I'll let you know, but in the meantime...here is the service manual for you.
Cheers
Paul
PS, well it seems I can't upload yet...I'll try another method for you
here ya go http://www3.telus.net/radioboy/trans...20overhaul.pdf
ve7kilohertz is offline
post #2 of 4 (permalink) Old 12-28-2008, 02:26 PM
Check with these guys if you need parts Dodge Transfer Case Parts
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #3 of 4 (permalink) Old 01-18-2011, 09:11 AM
cumminscat345's Avatar
auto or manual??
are the np241's the same in both the auto and manual trannys?? have a auto parts truck with a good np241, driving my manual with a bad one. i know the driveshafts are different, but do the splines match up? any help would be greatly appreciated!
'94 reg. cab 4x4 meyers poly plow, 5spd nv4500 np241, starwheel tuned, afc, 0 plate, 181 dv's silencer ring trash, custom 4" to 6" tip 4:10's 34's
cumminscat345 is offline
post #4 of 4 (permalink) Old 01-18-2011, 09:45 AM
answered my own question, they are different spline counts. thanks!
