Dodge Cummins Diesel Forum
Dodge Cummins Diesel Forum (http://www.cumminsforum.com/forum/)
-   94-98 Powertrain (http://www.cumminsforum.com/forum/94-98-powertrain/)
-   -   98 47RE vs 97 47RE (http://www.cumminsforum.com/forum/94-98-powertrain/1042186-98-47re-vs-97-47re.html)
jagert59 03-29-2014 10:18 PM
98 47RE vs 97 47RE
Can anyone tell me the specific difference between these 2 transmissions?
I have found a 97 trans that I would like to put in my 98 12 valve, but when I check on Car-Part.com--Used Auto Parts Market it only lists the 98 & 99 trans when I search for model year 98.
ghostman 03-29-2014 10:24 PM
No difference.
Sent from AutoGuide.com App
jagert59 03-29-2014 10:25 PM
All electrical and sensors conections are identical?
country_hick 03-30-2014 12:09 AM
The overdrive section may have 1 or 2 electrical connectors. My 1997 2wd has 2 plug ins on it. A 4x4 tail is different. The numbers of electrical connections the only real difference.
Dynamic 03-30-2014 12:27 AM
They are the same. Electronics are the same as well...
Plug and play...
bootstrap 03-30-2014 09:02 AM
2 Attachment(s)
I am not sure where you get that a 1997 2wd 47RE has two plug ins on the overdrive section. Here you will see that there is only one on the overdrive section. I assure you, the strap isnt covering a plug in. There are two on the main section, drivers side.
I doubt there was a change mid year of 1997. These pictures were taken while I removed the trans for the NV4500 conversion.
jagert59 03-30-2014 04:54 PM
Thank you all for the information!
Powered by vBulletin® Copyright ©2000 - 2017, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
