HX52 concerns - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 12-15-2013, 02:52 AM Thread Starter
59fordcummins's Avatar
HX52 concerns
So im helping a buddy build his Cummins, actually a P-pumped 24v, and we're putting an hx52 on as a single, 67/71/16. He's got a 181/210 Cam, 100hp injectors (not sure on the dimesions) and a 160 pump, with 19.5 timing, 100 plate, and 181 dv's. My question mostly how do you guys think it will spool? its going to be a daily driver with a goal of roughly 450-550 hp in mind. Ive been researching and some say they have weak shafts, some so they beat on them and are a fun turbo. any input would be great.
2008 Ford F-350 CCSB 6.4 Powerstroke ZF-6 Manual.
1997 F350 CCLB 12v Cummins
1994 Dodge 2500 RCLB 12v Cummins
59fordcummins is offline
post #2 of 19 (permalink) Old 12-15-2013, 07:15 AM
revemup15's Avatar
160 pump will need fullcuts
95 farm truck
revemup15 is offline
post #3 of 19 (permalink) Old 12-15-2013, 09:11 AM
Turbo is too big for your goals try looking for a 63/68 and the hx52 is laggy for a dd but can be a almost a smoke free setup if tuned right.
Sent from AutoGuide.com App
94 2500 4X4 RCLB 277K 20* 600cc benched pump 7mm dv 4k gsk airdog ll 200 5x.018 sac 63/68/.91 external gate 60lb valve springs trans built by me billet input dual disk shift kit
Montser633 is offline
post #4 of 19 (permalink) Old 12-15-2013, 10:42 AM Thread Starter
Trying to do this on a pretty tight budget, does anyone have a suggestion for a relatively cheap replacement?
post #5 of 19 (permalink) Old 12-15-2013, 01:32 PM Thread Starter
Would a s471 with a t4 1.00 be a better route?
post #6 of 19 (permalink) Old 12-15-2013, 01:58 PM
For 450 he351cw. Any thing much more than 450 62/65 and 500 is 63/68 and 575-600 is a 64/71. That being said there are other variables but a s471 and hx52 is a 600+ turbo with supporting mods.
The Following User Says Thank You to Montser633 For This Useful Post:
NC Firefighter (12-15-2013)
post #7 of 19 (permalink) Old 12-15-2013, 04:41 PM
NC Firefighter's Avatar
What he said that turbo is way too big for what you're trying to do. He351 would work very well for you and you could get it on and working for around $500. I don't see you getting 450hp out of a 160 pump with just 181s and stock injectors. Keep the 181s and get a set of quality 5x12s. I'd recommend DAP or DFI personally.
:EDIT I'm an idiot I just noticed the 100hp injectors. They're most likely 5x12s and would work well.
98 12 Valve, 5 Speed, 3.55 Gears, 35s, 4K Gov Springs, Timed 22 Degrees, 5x16s, 024 DVs, Homemade Fuel System, ARP Studs, Ported Head, 60LB VS, 64/64/9 HE351, Valair DD, 5 Inch Exhaust. 515hp/870ftlbs 4/8/16
NC Firefighter is offline
post #8 of 19 (permalink) Old 12-16-2013, 12:35 AM Thread Starter
So with the 5x12's you think the will make 450ish hp? Our thought behind the hx52, was have some room for more fuel before enough air became an issue. We thought the cam would help compensate for some of the lag. We considered a he351, but we're concerned with have a 9cm housing, things getting hot, do you think some 7x10's or 5x14's would make it more driveable? (more like 140-50hp injectors)
post #9 of 19 (permalink) Old 12-16-2013, 04:02 PM
jlbayes's Avatar
imo you are just looking for excuses to run the turbo. while yes it will work it is way over kill for the goals at hand. i would sell the turbo and find one that better suits the desired goal.
Jacob, "strictly business" 01 grumpy sob, Calibrated Addiction, Infinite Performance, Farrell Diesel, 97 rclb
jlbayes is offline
post #10 of 19 (permalink) Old 12-16-2013, 05:01 PM Thread Starter
Lol kind of yes, I've already got it, don't want to spend the money on a s300 turbo
post #11 of 19 (permalink) Old 12-16-2013, 08:10 PM
If you already have the turbo, you'll be fine, just spend some money on some valvesprings and don't shift before 3500rpm at WOT.
1989 D250 2wd Scheid 14mm VE pump, 5x25s, Air Dog II, Majestic Turbo 62/65/14 S300 NX two-stage. 47RH by J&H Performance. 487rwhp on fuel, 972rwhp on the jug.
1995 Dodge 160hp pump A3K/A5K twins, 564rwhp.
JQmile is offline
post #12 of 19 (permalink) Old 12-16-2013, 08:15 PM
If you plan on keeping the hx52 I'd run 5x16 with a bench pump or 5x18 on a stock pump it will spool better I have ran 5x12 an a hx52 and it was ok spool but jumped to 5x16 and spools faster and isn't so laggy
