4" downpipe? - Dodge Cummins Diesel Forum
Old 09-05-2008, 03:19 PM   #1 (permalink)
4" downpipe?
OK how does a dummy know which downpipe he has, and what gain do I get from a 4" downpipe on a stock 12V?
'94 2500 4X$ BHAF, silencer ring AWOL, Home-made Fuel press guage,KDP Finally Neutered! STR8 PIPE:thumbsup
corbinstein is offline   Reply With Quote
Old 09-05-2008, 07:08 PM   #2 (permalink)
AlGores worst nightmare
Racer9's Avatar
The downpipe is the exhaust pipe that comes out of the turbo and goes down to the exhaust. If it's about the size of a Coke/Pepsi can it's 3" which is stock. Also, the 4" usually is 3" at the turbo, and then flares out to 4" in the first 4-5". So if it stays the same size, it's probably stock 3", on a 12 valve truck.
'96 2500, CTD, 4X4 flatbed, Isspro gauges, Skyjacker D-25's, ThurenFab track bar, DSS, HD steering.
Motor; BHAF, #100 fuel plate, 5X.012 90hp injectors, Pacbrake 4kGSK, Loose starwheel. 306hp/743tq before injectors.
Exhaust; Schwitzer S300G, 4" downpipe, single 5" turnout stack.
Trans; Dunrite VB/TC, Intelligent Engineering billet input shaft, Burt Brown rebuild/upgrade.
Racer9 is offline   Reply With Quote
Old 09-05-2008, 07:16 PM   #3 (permalink)
Lower Slower Delaware
cowbully's Avatar
Good job explaining that Racer 9 It is very easy to tell once you know what your looking at! There is a huge gain going from stock to 4". Dont know if you have a pyrometer but the hot gasses will flow a heck of alot faster
'05' 3500 4x4 Laramie Dually AFE Intake and 5" stainless exhaust , Ranchand bumpers front and back, leveled on 35" AT2's
cowbully is online now   Reply With Quote
Old 09-05-2008, 07:16 PM   #4 (permalink)
Banned
On a stock truck you might get a touch of HP but mainly lower EGTs and you'd be preparing for a future of
awenthol is offline   Reply With Quote
Old 09-05-2008, 07:24 PM   #5 (permalink)
cameronc's Avatar
looks at the bends- if they look crimped you know you've got a stock downpipe.
94 reg cab 2wd/4k gsk/19.5*/cpp 7x.010's/sdx dv's/ and a big turbo in the works
cameronc is offline   Reply With Quote
Old 09-06-2008, 06:57 PM   #6 (permalink)
Newbie to 12v so forgive me, but are you saying opening the exhaust to 4" will increase the chance of ruining the stock tranny?
What are EGT's???
rocket-flash is offline   Reply With Quote
Old 09-06-2008, 07:08 PM   #7 (permalink)
Banned
Nope...what I meant was, intake and exhaust are just the beginning to dumping way to much money into performance mods . EGT = Exhaust Gas Temperature...when you start turning the pump up, etc, you'll increase combustion temps and too hot will result in melting things. A higher flowing exhaust (ie, 4") will allow air out faster and subsequently lower temps.
Old 09-06-2008, 07:37 PM   #8 (permalink)
Ok, I'm with ya...I knew turning up the turbo (chip/tuner, etc) required larger exhaust, but can you get performance out of a 4" down pipe w/o any other mods?
Old 09-06-2008, 07:42 PM   #9 (permalink)
Banned
Like I said before...you might get a couple horsepower and possibly some mpgs but you're generally only planning for future mods...
Old 09-07-2008, 07:56 AM   #10 (permalink)
Racer9's Avatar
You won't gain any power, you might recover a little that is lost in a restrictive exhaust system, and it will help the motor breathe better, and run cooler.
You cannot "chip/tuner" a 12 valve. It is an all mechanical motor, which means all power upgrades require getting a little grease on your hands, and working up a little sweat. The plus side is that's all some of the upgrades require, in other words, FREE power.
Old 09-17-2008, 02:53 PM   #11 (permalink)
I'll take some free power!
can you tell us how?
Old 09-18-2008, 12:55 PM   #12 (permalink)
Do a search for free or cheap upgrades here and you will find plenty. Once you start, you won't be able to quit.
Chuck
'97 3500, Ext. cab, long bed, 4x4, 5 spd, 3.54s, KDP killed, silencer ring MIA, HD valve springs, Vulcan big lines & draw straws, Raptor 150, 5x14 injectors from Coaltrain, 4K gsk, 15*, custom fuel plate, BHAF, 5" turbo back, Thanks to Richard at Coaltrain
ChuckV309 is offline   Reply With Quote
