| 94-98 Performance Parts Discussion Discussion of Performance Parts For the 94-98 Trucks No Advertising ...NO ADVERTISING |
Truck wont start, unless I tap the throttle?
Does anyone have an idea as to why my truck will turn over and over and eventually after 10 seconds or so it will start. But if i tap the throttle it will fire right up?
1997 12valve automatic regular cab white completely stock! |
#2 (permalink) |
sounds fuel related...
02 24 valve, 35" BFGs, fass 95, CoaltrainDiesel100's, laramie slt, banks jake brake, dark tint, ATS tranny pan, silencer ring?, Smarty, leveling kit, suncoast stage IV all billet by FLEECE PERFORMANCE, adrenaline, 8 in CAT stack
#3 (permalink) |
Moderator
Sounds like both of my trucks by choice because I like the idle set lower than spec. I prefer to give it a little throttle when starting rather than hear it roar when idling. If you prefer to not to give it a little start up pedal then turn up the idle. Instructions> 12 Valve Idle Adjustment
Bill '95 2500 4wd auto '95 3500 5 speed heavy hauler Both far from stock Last edited by illflem : 08-29-2008 at 08:42 AM. |
#4 (permalink) |
Mine did the same thing until I turned the low idle screw
FOR SALE 97 dodge ctd with loadstop exchange, govenor spring kit 4k, valve springs #60, 375 marine inj., laser cut delivery valves, 5spd, haisley double disc street puller clutch, bigger turbo, afe air filter, 5" stacks, pyro, boost, tranny temp guages |
#5 (permalink) |
a buddy of mine's 96 12v does that, he has leaky fuel lines.
Nothing yet, and probably nothing until next year, i feel so left out! Global climate change is natural phenomenon, exploited by the unscrupulous, for political and monetary gain. |
#6 (permalink) |
idle too low, mine was the same way, even if its only as low as 600rpm it wouldnt fire up right away.
97 Ram 2500 / 5.9ctd / 5spd / nv4500 / 4x4 / np241 Starwheel cranked, no plate, autometer pyro and boost gauges, Single 4" stack, 33x10.5 Mud terrains, tons more to come
#7 (permalink) |
Okay I just turned the Low Idle Screw up and now it is beautiful! truck fires right up and idles right where it needs to be! I appreciate all the help you guys have been! If any of you have questions about Edge or anything PM me, I will be happy to help as much as I can. Thanks, -Jerry
#8 (permalink) | |
96 2500 GONE! New 1996 3500: Full billet DTT, pac brake, #10,timing,AFC spring kit,3GSK,5X12s,58/14 Hybrid, lockup controller,3 piece, 105,000MI |
#10 (permalink) |
mine does the same thing ........... but i have my idle set at 900rpms. AND i have NO fuel leaks... it has got to do with how you have the governor set upl. Lance
'97 black dually 64mm/74mm twins, helix II, cooltwist IC, 435's, lasercuts, .093 lines & holders, 4k gsk, custom rack plug, 3850 DD, dual aussies |
