Hx35 hybrid or hx40? - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 07-03-2013, 11:33 AM Thread Starter
cumminhot97's Avatar
right now I am in the process of figuring out which turbo is best my truck has 191 delivery valves, mack plug, timing@16.5*, number 100 fuel plate, and hx35 turbo wastegated to 30 pounds of boost. What is the best choice for me I have an hx35 laying around and I have an hx40 off of an 8.3 liter cummins what is the best decision for me? thanks guys.
97 dodge 2500 4x4 3" Carli coils, fox 2.0's
cumminhot97 is offline
post #2 of 19 (permalink) Old 07-03-2013, 01:04 PM
Diesel Auto Power
jkidd's Avatar
iTrader Score: 21 reviews
If the hx40 Is the 16 cm I would use it, or consider selling both and getting a new one of the size you want
Sent from AutoGuide.com App
Monday-Thurday 7:30AM-5:30PM
Friday 7:30AM-4:30PM
Call 801-282-6037
---Military Discounts Available---
jkidd is offline
post #3 of 19 (permalink) Old 07-04-2013, 02:26 AM
VP of the dry side
cumminsrulez's Avatar
Put the hx40 on Lol
Sent from the Chodster
97,2wd, auto swapped, Moss Green, 211k, s&b,4in with muffler stock tip
(stealth mode engaged
) ,afc mods, kdp,egt boost fp dp,22*,Haisley 5k gsk-60pounders,traction bars, A1 studs+Oring'd block, P&P, A1000 custom fuel setup,5x.018 SAC 145* 300 bar,.025 dvs, 64.5/68/.83 t4 sxe 50mm jgs gate/w screamer pipe
Originally Posted by dvst8r View Post
Dying is always a way bigger concern than egt's...
cumminsrulez is offline
post #4 of 19 (permalink) Old 07-05-2013, 08:38 PM
God prefers Diesels's Avatar
If you want a slow-spooling dog, I'd say go with the 40.
As far as the hybrid - I had one and loved it.
93 Chevy with '97 215 47rh 241DHD HE351cw/bht3b(26cm) Con7x12tagious
Originally Posted by billow99 View Post
i hate nv 4500s i keep breaking the cluster gear. even with cryo treating. its pointless to expect them to hold up to any abuse.
Originally Posted by randemelissa View Post
You want smoke? throw a rag in your air filter inlet. you want power? we'll help all we can.
God prefers Diesels is offline
post #5 of 19 (permalink) Old 07-05-2013, 10:23 PM
VP of the dry side
I don't think the hx40 would be bad honestly. Friends in what you want and what you plan to do
post #6 of 19 (permalink) Old 07-05-2013, 11:05 PM Thread Starter
Yeah I just would like a decant turbo that won't fall apart and that's on a budget my truck isn't a 600hp street truck just a little tuned up that's all
post #7 of 19 (permalink) Old 07-06-2013, 12:50 AM
VP of the dry side
Try the hx40 if you don't like it make a hybrid
post #8 of 19 (permalink) Old 07-06-2013, 02:23 AM
NC Firefighter's Avatar
Far as I know the hybrid compressor wheels are just hx40 wheels. So both should flow the same on the compressor side. Personally I like quick spool and the hybrid should spool faster and easier than the 40 so I'd probably go that route. I'd drill out the gate port as big as I could though to help hotside flow. Airflow wise though, both should be a pretty good match for your fuel.
98 12 Valve, 5 Speed, 3.55 Gears, 35s, 4K Gov Springs, Timed 22 Degrees, 5x16s, 024 DVs, Homemade Fuel System, ARP Studs, Ported Head, 60LB VS, 64/64/9 HE351, Valair DD, 5 Inch Exhaust. 515hp/870ftlbs 4/8/16
NC Firefighter is offline
post #9 of 19 (permalink) Old 07-06-2013, 12:04 PM Thread Starter
I just want to be able to build my boost with without it being hot air I know the hx40 will be fine at 40 psi but what's the most a hybrid can handle ?
post #10 of 19 (permalink) Old 07-06-2013, 01:30 PM
MrExtreme's Avatar
I am running the HX35/40 hybrid, the manufacturer said it was good for around 40 PSI. The problem with the HX40 is the shaft has a reduced diameter at some point and is known to break, that is why the hybrid is better as it uses the HX35 shaft which is the same diameter all the way, but has more flow with the HX40 compressor.
92 CC LE W350, 215 HP P-Pump, 450 CC, 20 timing, HX 35/40 60/60/14 CM gated, S475, Air Dog 200, ATS exhaust manifold, custom air intake,ARP head and main studs, ported head, 24 V oil pump.
MrExtreme is offline
The Following User Says Thank You to MrExtreme For This Useful Post:
God prefers Diesels (07-07-2013)
post #11 of 19 (permalink) Old 07-06-2013, 02:53 PM Thread Starter
Ok good then so hybrid seems better choice for me
post #12 of 19 (permalink) Old 07-06-2013, 08:10 PM
Ducati M.
DMan1198's Avatar
When I built my hybrid I actually used an hx40 cartridge that was from an 8.3 and the aftermarket wheel was bigger than the hx40's wheel. I did swap the wh1c shaft and turbine housing onto it though and ran 40 psi
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM w/MCC, OD, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan,
v2 Finally doing stuff
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
Instagram:
DMan1198 is online now
