cheap head studs - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 04-19-2013, 07:47 PM Thread Starter
cheap head studs
Search has showed cheap upgraded bolts from mcmaster-car, fastenal service and mighty diesel. What about head studs? Any cheaper alternatives to the arps? I would prefer studs over bolts because everything else being equal the studs would be stronger. The tension on studs is a vertical tension where as the bolts have torsional and vertical tension.
1998 2500 quad cab, 4x4, 12v, 4:10 gears, amsoil bhaf, hid's projector headlamps, h2 wheels/tires, hog performance 4" exhaust, 2" lift, isspro gauges, boost elbow, 3k gsk, agr box and pump, #10 plate. triple disk TC, head studs, 5x12 injectors
quinton is offline
post #2 of 8 (permalink) Old 04-20-2013, 01:41 AM
all go no show's Avatar
I don't think anybody has come up with a cheap stud kit. Search grade 8 studs/bolts. There was a big thread going a few months ago about all the stud/bolt options
95 2500 4x4, auto
all go no show is offline
post #3 of 8 (permalink) Old 04-20-2013, 02:01 AM
VP of the dry side
cumminsrulez's Avatar
Here you go. Read away lol
anyone ever use a grade8 stud vs arp?
97,2wd, auto swapped, Moss Green, 211k, s&b,4in with muffler stock tip
(stealth mode engaged
) ,afc mods, kdp,egt boost fp dp,22*,Haisley 5k gsk-60pounders,traction bars, A1 studs+Oring'd block, P&P, A1000 custom fuel setup,5x.018 SAC 145* 300 bar,.025 dvs, 64.5/68/.83 t4 sxe 50mm jgs gate/w screamer pipe
Originally Posted by dvst8r View Post
Dying is always a way bigger concern than egt's...
cumminsrulez is offline
post #4 of 8 (permalink) Old 04-20-2013, 02:09 AM
cumhands's Avatar
408 is the cheapest I found them online with free shipping. That's for ARPs
1998 12v holy grail
cumhands is offline
post #5 of 8 (permalink) Old 04-20-2013, 11:52 AM Thread Starter
Originally Posted by cumminsrulez View Post
Read that one already. No source of bolt store studs found on those posts
Sent from my C771 using Tapatalk 2
quinton is offline
post #6 of 8 (permalink) Old 04-20-2013, 12:14 PM
It's highway robbery over 400 for stud kit. Arp has a monopoly on the cummins stud kits hence the high price
95 2500 ctd 4x4 #10 plate 4"exh 3k gsk 16* 35 psi
96 f-250 4x4 7.3 auto
corn binder is offline
post #7 of 8 (permalink) Old 04-20-2013, 12:26 PM Thread Starter
I agree should be no more than half what they charge
quinton is offline
post #8 of 8 (permalink) Old 04-20-2013, 03:35 PM
Sasquatch
crazyrunner33's Avatar
400 dollars for 26 studs is actually pretty reasonable, less than 16 dollars a stud. Not bad when considering the cost to heat treat and straighten them is pretty high. Extreme-Studs sells some nice head studs that are just as strong as the ARP New Age studs, but that still puts them at almost 700 dollars.
'97 ECLB NV4500 compound mufflers, Banks stacked with Edge Juice w/Attitude, throttle sensitivity booster, lockup switch, wastegate delete
'10 VW Golf TDI DSG, High Performance DPF, low friction timing belt
crazyrunner33 is online now
