AFC and boost question - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 03-24-2013, 01:06 AM Thread Starter
matt72991's Avatar
ok so on my truck so far ive only done the free or cheap stuff to. exhaust, intake, fuel plate. and got boost and pyro guages.. been running 32 psi max. as far as i know there isnt a boost elbow and it is an hx-35 still. ive never done anything with the turbo itself.. but this weekend i finally got around to doing the afc modding.. took it off and ground down the afc barrel and swapped in a flat washer for the cupped washer. i put it all back together and set the pre boost screw in a little. just enough to wear i saw it push the foot forward. i plan to turn it back out but put it back on the truck and now im hitting 37 psi at WOT... is this normal or is something wrong with my wastegate/turbo. i bought the truck stock and its only gotten what ive put into it. so my question is why after modding the afc am i getting 5 extra psi of boost??? thanks in advance
1996 2500 Crew Cab, 2wd, manual trans swap, #100 Plate, BAHF, straight pipe to 5" stacks, afc mods.
matt72991 is offline
post #2 of 4 (permalink) Old 03-24-2013, 11:49 AM
VP of the dry side
cumminsrulez's Avatar
Re: AFC and boost question
Your wastegate may be stuck. But to answer why it gained more boost its because you allowed for more rack travel with the afc
97,2wd, auto swapped, Moss Green, 211k, s&b,4in with muffler stock tip
(stealth mode engaged
) ,afc mods, kdp,egt boost fp dp,22*,Haisley 5k gsk-60pounders,traction bars, A1 studs+Oring'd block, P&P, A1000 custom fuel setup,5x.018 SAC 145* 300 bar,.025 dvs, 64.5/68/.83 t4 sxe 50mm jgs gate/w screamer pipe
Originally Posted by dvst8r View Post
Dying is always a way bigger concern than egt's...
cumminsrulez is offline
post #3 of 4 (permalink) Old 03-24-2013, 11:52 AM Thread Starter
matt72991's Avatar
Oh ok so its should fain boost ok. No I do I go about finding out of.my Wastegate is stuck?? A buddy of mine said it could also.be the actuator on the wastegate also???. Could it be? If so how do I test these??
post #4 of 4 (permalink) Old 03-24-2013, 12:31 PM
CTD2500's Avatar
Find the end of the line going to the wastegate that's easiest to get to and use some compressed air (regulate it to about 40-50 PSI if possible). Blow into the line and see if the wastegate actuator moves.
95 Ram 2500 RCLB, 4x4, 4K GSK, 024 DVs, 5x.018, 19, 4" exhaust, 257/4202 turbos, 178-208 cam, ported head, BD SS manifold, Tunnel Ram, 2 intercoolers, Goerend T/C, ATS V/B, built 47RH...02 VW Golf TDI, 5 spd, Colt Cam, EGR/cat delete
CTD2500 is offline
