need better fuel mileage - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 03-19-2013, 03:10 PM Thread Starter
what is the easiest or better yet the least expensive way i can get better fuel mileage outta my 98 12v? anything will help just moved and the commute is a beast
aggieredneck12 is offline
post #2 of 4 (permalink) Old 03-19-2013, 03:20 PM
VP of the dry side
cumminsrulez's Avatar
Re: need better fuel mileage
I know diesel power mag did some stuff for free to a dually that got it almost 30mpgs. I'll look for the article. Other than that. Freshen injectors, clean air filter, stock tires, timing, and a mild smoke free afc tuning.
97,2wd, auto swapped, Moss Green, 211k, s&b,4in with muffler stock tip
(stealth mode engaged
) ,afc mods, kdp,egt boost fp dp,22*,Haisley 5k gsk-60pounders,traction bars, A1 studs+Oring'd block, P&P, A1000 custom fuel setup,5x.018 SAC 145* 300 bar,.025 dvs, 64.5/68/.83 t4 sxe 50mm jgs gate/w screamer pipe
Originally Posted by dvst8r View Post
Dying is always a way bigger concern than egt's...
cumminsrulez is offline
post #3 of 4 (permalink) Old 03-19-2013, 03:32 PM
NC Firefighter's Avatar
^^^^Agreed. Make sure everything works like it's supposed to first. Make sure the fuel system is supplying adequate, clean fuel. Check and change the filter if needed, and clean the pre-filter. Breathing in and out is important, a BHAF wouldn't hurt. Also if your exhaust is in bad shape you might pick up a little mileage with a 4 inch system. I have found that once I installed my gauges my mileage went up some, because I started driving different. You want to keep your EGTs and boost both as low as possible for best mileage. Low temps mean clean, efficient combustion and low load. Low boost means low load and low drive pressure. Timing will also help.
98 12 Valve, 5 Speed, 3.55 Gears, 35s, 4K Gov Springs, Timed 22 Degrees, 5x16s, 024 DVs, Homemade Fuel System, ARP Studs, Ported Head, 60LB VS, 64/64/9 HE351, Valair DD, 5 Inch Exhaust. 515hp/870ftlbs 4/8/16
NC Firefighter is offline
post #4 of 4 (permalink) Old 03-20-2013, 10:38 AM Thread Starter
10-4 guys appreciate the input
