12v pump mods with no power gain - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 01-12-2013, 03:40 PM Thread Starter
Philman4461's Avatar
Hey guys, im new to the forum. Ive got a 12v i did some pump mods (removed fuel plate, turned up star wheel and turned smoke screw in just a bit). I noticed no power increase and no smoke. Im not looking to dump smoke just want to get it to smoke so i can tune my afc. The boost lines that connect to the afc are new and ive got good fuel pressure from the lift pump. Not sure on the psi. But the lift pump defiantly puts out some pressure because i lost the supply line from the filter to the p7100 and when that went there was plenty of fuel coming out of that line. Replaced that line with a half inch fuel line. Im stumped on wat to check next. Any ideas????
94 dodge ram 2500 12v cummins 201k, 47rh auto trans (stock rebuilt), 4in exhaust with diesel glasspack, bhaf, ats arc air flow, adjustable tork tek ofv, pump mods, od and tc lock up switches.
Philman4461 is offline
post #2 of 22 (permalink) Old 01-12-2013, 04:27 PM
You need to check fuel pressure and if low it can be cause by the overflow valve 18 psi at idle min and at wot shouldn't go below 20 psi
Sent from my iPhone using AutoGuide.com App
94 2500 4X4 RCLB 277K 20* 600cc benched pump 7mm dv 4k gsk airdog ll 200 5x.018 sac 63/68/.91 external gate 60lb valve springs trans built by me billet input dual disk shift kit
Montser633 is offline
post #3 of 22 (permalink) Old 01-12-2013, 04:32 PM Thread Starter
Forgot to mention that i also put in an adjustable ofv from tork tek
post #4 of 22 (permalink) Old 01-13-2013, 12:32 PM
VP of the dry side
cumminsrulez's Avatar
You did move the starwheel the right way right?..turning towards the motor. not calling you stupid but i've seen it done
On Cummins forum instead of working or doing homework.
97,2wd, auto swapped, Moss Green, 211k, s&b,4in with muffler stock tip
(stealth mode engaged
) ,afc mods, kdp,egt boost fp dp,22*,Haisley 5k gsk-60pounders,traction bars, A1 studs+Oring'd block, P&P, A1000 custom fuel setup,5x.018 SAC 145* 300 bar,.025 dvs, 64.5/68/.83 t4 sxe 50mm jgs gate/w screamer pipe
Originally Posted by dvst8r View Post
Dying is always a way bigger concern than egt's...
cumminsrulez is offline
post #5 of 22 (permalink) Old 01-13-2013, 12:39 PM
Moderator
9297oldram's Avatar
Your not going to have power when your blowing smoke, all that does is flood your turbo until it can build up enough boost to try to make use of the extra fuel. If you want power you need to tighten the starwheel.
92 D250 parted out
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 4x4 with 92 Cummins zf5
9297oldram is offline
post #6 of 22 (permalink) Old 01-13-2013, 12:46 PM Thread Starter
Yes starwheel is turned the right way. Im not looking to roll coal i just want to fine tune my afc. And with the mods i have done there should be more power and smoke. I just want power not smoke. Ive read up alot on the pump mods. Im just trying to figure out why i have no power increase with the mods i have done?
post #7 of 22 (permalink) Old 01-13-2013, 12:52 PM
Moderator
9297oldram's Avatar
So then before the turbo spools up do you get alot of smoke?
How many miles are on your injectors?
92 D250 parted out
post #8 of 22 (permalink) Old 01-13-2013, 01:25 PM Thread Starter
I get no smoke at all. And i believe the injectors r stock with 194k on them.
post #9 of 22 (permalink) Old 01-13-2013, 01:31 PM
Moderator
9297oldram's Avatar
You might want to put a fuel pressure gauge on to see if your getting enough fuel pressure.
Is your fuel filter and air filter clean?
92 D250 parted out
post #10 of 22 (permalink) Old 01-13-2013, 01:47 PM Thread Starter
Ya the fuel pressure gauge is next on the list. The air and fuel filter r both new only about 2000 miles on them
post #11 of 22 (permalink) Old 01-13-2013, 01:49 PM Thread Starter
The only other thing i could think of is that the diagphram in the afc is leaking/ has a hole in it?
post #12 of 22 (permalink) Old 01-13-2013, 01:49 PM
Moderator
9297oldram's Avatar
Stock injectors are only good for about 200,000 miles and they should be rebuilt or replaced.
If that is leaking then your pump isn't going to get boost pressure that could be your problem.
92 D250 parted out
