P7100 fuel psi gauge?? - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 09-28-2012, 08:31 PM Thread Starter
DOG5.9's Avatar
I want to make sure I have full pressure on my inj pump. Would consider raptor pump plus fuel psi gauge. Most of the write-ups are 24v due to their inj pump fuel pressure issue. Please point me in the right direction for correct fuel psi on 12v!!
'95 4WD leveled, front sway removed (rear added) 285/75r17s and 4.10s. mild fuel, non WG 62/65 turbo. L/U switch, and POT knob installed on the tps's GROUND WIRE ONLY. work truck and stuff
DOG5.9 is offline
post #2 of 12 (permalink) Old 09-28-2012, 09:49 PM
VP of the dry side
cumminsrulez's Avatar
At idle it should be 17-22 psi and at 2500 rpm no load should be 25 and up I believe. It shouldn't go down with higher RPMs.
On Cummins forum instead of working or doing homework.
97,2wd, auto swapped, Moss Green, 211k, s&b,4in with muffler stock tip
(stealth mode engaged
) ,afc mods, kdp,egt boost fp dp,22*,Haisley 5k gsk-60pounders,traction bars, A1 studs+Oring'd block, P&P, A1000 custom fuel setup,5x.018 SAC 145* 300 bar,.025 dvs, 64.5/68/.83 t4 sxe 50mm jgs gate/w screamer pipe
Originally Posted by dvst8r View Post
Dying is always a way bigger concern than egt's...
cumminsrulez is offline
post #3 of 12 (permalink) Old 09-29-2012, 12:42 PM Thread Starter
DOG5.9's Avatar
Naw 12v is supposed to see upward of 35 psi. This leaves a lot of room I'm wondering if truck is running good or anemic without gauge though
Sent from my iPhone using AG Free
DOG5.9 is offline
post #4 of 12 (permalink) Old 09-29-2012, 01:29 PM
VP of the dry side
No those numbers are minimums. Mine idles around 30 and goes up to around 40 at some times. Around 30 is best
post #5 of 12 (permalink) Old 09-29-2012, 06:08 PM Thread Starter
DOG5.9's Avatar
Cool may I get some advice on your pump/gauge setup for it?
DOG5.9 is offline
post #6 of 12 (permalink) Old 09-30-2012, 01:46 AM
VP of the dry side
Sorry I didn't get back to this earlier lol. I was on the dyno. But anyhow I just have a carquest 100 psi oil pressure gauge hooked up to a 1/8in npt needle valve with male and female ends, drilled and tapped into the banjo bolt on the pump
The Following User Says Thank You to cumminsrulez For This Useful Post:
DOG5.9 (10-04-2012)
post #7 of 12 (permalink) Old 10-04-2012, 05:26 PM Thread Starter
DOG5.9's Avatar
tons of fun looking behind the brake parts and mapping out what I wanna do but I will start with LarryB's fuel gauge kit PLUS adjustable ofv.
I've had a hard time figuring out how to do a lift pump delete (like put it on a shelf delete). I don't care for the idea of installing a FASS/Airdog with all the redundancy
DOG5.9 is offline
post #8 of 12 (permalink) Old 10-05-2012, 02:27 AM
customharvester2011's Avatar
If you have mechanical lift pump get the tork tek ofv 020 adjustable.
Sent from my ADR6350 using AutoGuide.Com Free App
160hp pump, .025dvs/7x.011 sticks( poor little hx35
, thanks Will! ),racked barrels, 2095 rack plug, AirDog2 165, AFC Mods, AFC FF, Plate MIA, 16.5*timing, 4ks, 60lbers, boost elbow@40psi, stock down pipe to 5" stacks. Built 47rh and hx52 next.
customharvester2011 is offline
post #9 of 12 (permalink) Old 10-05-2012, 03:27 AM
lostnwalmart's Avatar
I have mine set to idle at 55 and with the adjustable regulator it goes up with boost from there. But my setup is overkill for most.
06 vw jetta tdi
94 dodge
-Cliff
lostnwalmart is offline
post #10 of 12 (permalink) Old 10-05-2012, 11:08 AM
VP of the dry side
Isn't that much bad for the seals? Or is it a built pump
post #11 of 12 (permalink) Old 10-05-2012, 01:26 PM
ARbowhunter7's Avatar
IIRC, he's got a built pump. I run constant 40 psi to mine.
And OP, to delete the lift pump you need a block off plate from a Big Block Chevy (around $10) to cover the hole in the block where the lift pump was. Then just run the Raptor straight to your IP, and splice a filter in somewhere.
1998 12V 3500 4x4...You know what it is
ARbowhunter7 is offline
post #12 of 12 (permalink) Old 10-05-2012, 02:26 PM Thread Starter
DOG5.9's Avatar
Is there a difference between Larry's/torktek's ofv versus the one on my pump that has a bolt also going in it?
My kit is in the mail but DDP said my kit isn't going to do much/anything this afternoon. I'm wondering if it will sit on the shelf when it gets here
DOG5.9 is offline
The Following User Says Thank You to DOG5.9 For This Useful Post:
Maniac (07-14-2016)
