Gillett Diesel Turbo Upgrade - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 08-15-2012, 09:20 PM Thread Starter
Hey everyone, ive done a bit of searching on here and haven't seen alot of feedback for the gillett diesel turbo upgrade. My truck has the mods and sig and of course ill do injectors when i do my turbo upgrade. I'm looking at the 60mm compresor housing with the 6 blade wheel, and possibly a 14cm exhaust side. Anyone have any expierience with this upgrade?(or gillett diesel) I want a little more feedback before i go ahead and get it.
Thanks
97 3500 5spd, 4wd, 190,000, #100 plate ff, afc mods, 4gsk, cai, 5 inch pipe, autometer boost, pyro, and fuel pressure gauges
Cummins 24 is offline
post #2 of 14 (permalink) Old 08-15-2012, 10:33 PM
mikes5.9's Avatar
im looking to do the same but havent found anything either
1994 Dodge Ram 3500 4x4 5spd straight cab custom aluminum flat bed srw #11 plate full forward afc modded and tuned boost elbow at 30psi 4k gsk amsoil air filter sitting in the bottom half of the stock air box 4in turbo back straight exhaust
mikes5.9 is offline
post #3 of 14 (permalink) Old 08-16-2012, 05:21 PM Thread Starter
It seems like a pretty good deal, but i hear ya. I def want some user feedback before i shell out the cash for it.
post #4 of 14 (permalink) Old 08-16-2012, 05:24 PM
MotorCityMadman's Avatar
Give me a hand on my thread and I can tell you how the darn thing works!
98 2500,4x4auto,48re vb,billet single,shift kit+, Super B, 4" ss,#10 ff,4gsk,.024s, 5x.014, BHAF,16* gauges,WVO, B164 bypass 2004.5 3500, SRW, FASS WVO, B164 bypass, Edge@1 Sold 96 2500 eclb 3gsk
MotorCityMadman is offline
post #5 of 14 (permalink) Old 08-17-2012, 05:03 PM
USARMY12V's Avatar
6 blade 60mm requires machining while the 8 blade does not. 8 blade surges more and GDS said the 6 was better. Also said $40 to do the machine work.
98 QCLB 4x4 GT37, Contag!ous Diesel, DPC Converters. Team AirDog
2010 MCSB 68RFE w/Overdrive, XRT Pro, Draconian MCC. Sinister EGR/Cooler delete, Flo-Pro.
USARMY12V is offline
post #6 of 14 (permalink) Old 08-17-2012, 09:00 PM
Just got my 6 blade in. Way better than the 8. The 8 surges quite a bit with an auto and the 6 has not surged yet. My advice would be to not get the 8 under any circumstances. Hit 50 psi wot with it. As well the 6 blade is supposed to flow significantly more air.
Steve Wright at Gillett was very helpful. Tell him Kevin from Mb sends his best.
post #7 of 14 (permalink) Old 08-17-2012, 10:00 PM Thread Starter
What exactly has to be machined?
post #8 of 14 (permalink) Old 08-17-2012, 10:03 PM
The face plate that the compressor wheel sits recessed in.
post #9 of 14 (permalink) Old 08-17-2012, 10:26 PM
darren820's Avatar
I put a 60mm compressor upgrade on mine when I built my 5x.012 injectors. It definately helped, but not quite as much as I had hoped. Also its just pushing alot of hot air above 42ish lbs of boost. 14cm exhaust housing would be a nice addition.
In my opinion you end up with alot of dollars invested in a turbo that still has a weak shaft with a larger wheel on the end. Dont bark it too much or you'll be slinging parts. Something i would like to try is putting the 16cm nongated housing off a wh1c on the exhaust side and see how that helps.
1998 ECSB 12v. Goerend Trans/TC. A1 Studs. 0 Plate FF. 191 dvs. S&B Intake. 4" downpipe to 5" Straight Pipe. 4K GSK. 5x.012 injectors. 63/68/.83 t4 on polished SD manifold. Adj ofv. Isspro gauges.
darren820 is offline
post #10 of 14 (permalink) Old 08-18-2012, 02:49 PM
Bullrack's Avatar
I have the GDS 60mm wheel on my secondary with a non-gated 12cm housing. Can't beat the quality and sure makes for a sweet spooling set of twins!
2003 F350 CC XLT 4X4 DRW Manual TC, ZF6, 12 Valve Cummins, 60mmGDS-HX35/HT3b Twins, JGS 40mm WG, 5X16 inj.,O-ringed/P&P head with 60# springs, Colt cam, Mahle 210 Pistons, 4K GSK, 20* timing, Valair Kevlar/Ceramic Clutch.
Bullrack is offline
post #11 of 14 (permalink) Old 08-18-2012, 11:04 PM Thread Starter
So when i buy the turbo i just need to tell em that i want a 6 blade compressor wheel and ask them to machine it?(i want the 60mm compressor) Thanks.
post #12 of 14 (permalink) Old 08-18-2012, 11:30 PM
USARMY12V's Avatar
Yep. It's essentially a 35/40 hybrid kit for all intents and purposes.
The Following User Says Thank You to USARMY12V For This Useful Post:
Cummins 24 (08-19-2012)
