Old 03-05-2008, 07:29 PM   #1 (permalink)
JeepinOverU's Avatar
Need help tuning 12V
Trying to tune my 12V today. My problem is right when I get to 6psi or so of boost it lets out way too much smoke, even if im accelerating normally. The rest of the time fueling is ok. What adjustment can I make to it?
97 12v 2500 4x4 hx35/ht3b, sdx 5x.014, studs, 4k gsk, etc.
JeepinOverU is offline   Reply With Quote
Old 03-05-2008, 07:48 PM   #2 (permalink)
an intake would cut down the amount of smoke.
95 12v 2wd, reg cab, long bed.
a3ftgiant is offline   Reply With Quote
Old 03-05-2008, 08:17 PM   #3 (permalink)
First thing you want to cheak is your air filter and clean the housing, cheak your turbo and see that it spins freely. Unless you know someone who is a diesel Mechanic call around to radiator shops and diesel shops and get a price to test your air to air core, they test for leaks. Then do a valve set. That should keep you busy for a while. PLAY SAFE!
JP 3 :Licenced HD mechanic for 35 years. RETIRED! worked on engines all my life. Spent last 19 HAPPY years at Freightliner:
jpringle3@hotmail.com is offline   Reply With Quote
Old 03-05-2008, 08:17 PM   #4 (permalink)
Silverbulletdriver's Avatar
Tighten up the star wheel on the aneroid a bit if u want more boost before the fule comes on.
2001 dodge ram pulling truck.Built everything.Best dyno with single VGT 735hp 1287 ftlbs.:thumbsup
Silverbulletdriver is offline   Reply With Quote
Old 03-05-2008, 08:25 PM   #5 (permalink)
Tech Specialist
SmokinDiesel's Avatar
Nice numbers on a single charger! ... How is the drivability? ... Super Laggy?
Michael Charlton - Keystone Diesel
SmokinDiesel is offline   Reply With Quote
Old 03-05-2008, 11:40 PM   #6 (permalink)
Thanks, I will try the starwheel I just wanted to make sure that was it just because it was happening after 6psi or so.
Old 03-09-2008, 01:32 AM   #7 (permalink)
Bomaster238's Avatar
it could be a bad fuel filter....who knows haha
94 12valve 5 speed.5" single stack,AFE intake,Holset H1E, bosch 370s, TST #6, Schied Diesel DVs, HD valve springs, FASS150 A-meter Pyro and boost, boost elbow, KPD killed,16.5*, 550hp clutch on the way, leveling kit, 35s
Bomaster238 is offline   Reply With Quote
Old 03-09-2008, 01:45 AM   #8 (permalink)
You knew you were going to get smoke when you gutted the afc. Right. Did you cut the foot down or off? If so the starwheel will not do anything for you. Sounds like you will have to pull back some on the plate?
04.5 3500 srw QC 6 spd., silver,PPE, Quad B.F., cfm+, holley push pump,str8 piped.
81 short bed chevy race truck 97 12v, all the goodies.
stock600 is offline   Reply With Quote
Old 03-09-2008, 09:57 PM   #9 (permalink)
97cummins13's Avatar
id try to turn the star wheel back and slide the fuel plate back if the star wheel isnt enough.
'97 Ext Cab SLT 2500 4x4 5spd, SB 3600 DD,1 3/8" input, 17*, #100 plate forward, star wheel cranked, manual boost controller, single 5" stack, gauges, cold air intake, and 3" skyjacker lift.
97cummins13 is offline   Reply With Quote
