Removed Fuel Plate and Lost Power HELP - Dodge Cummins Diesel Forum
Old 05-30-2012, 09:56 AM   #1 (permalink)
scott6.7's Avatar
Question Removed Fuel Plate and Lost Power HELP
Removed my fuel plate, and result was a loss in power. Put it back in and slid it forward and gained a lil bit. the plate is a #10. I was reading in a thread that you can just remove the plate. Can anyone help me to understand as to why I gained no power?? The afc is all stock and has not been "adjusted" yet, was really more curious as to what i would get outta removing the plate first. Im new to 12v's.......more of a common rail guy.
98 12v cummins
Yes the tranny will handle the power
Yes I have straight pipe
Yes I have pyrometer
Yes the turbo will support the fuel when I can obtain it
Thanks in advance!
2011 Laramie Longhorn 4X4 : S&B Cold Air Intake / AFE Intake Elbow / H&S Rail Plug / H&S EGR Cooler Delete / Black Maxx / H&S Trans Tuning / GDP Grid Heater Delete / Flo Pro 5" SS TBE / Black Ops Wastegate / 35X12.5" Nitto Trail Grappler M/T
scott6.7 is offline   Reply With Quote
Old 05-30-2012, 10:05 AM   #2 (permalink)
scott6.7's Avatar
Oh and sorry if this was already answered somewhere else, if you could just point me in the right direction. Thanks again
Old 05-30-2012, 12:25 PM   #3 (permalink)
VP of the dry side
cumminsrulez's Avatar
I can't particularly explain it. But if you took the plate out and tuned the afc just like if you tune the afc with the 10 plate you will get more power out of it. When i took my plate out it seemed to have more power till i hit fifth gear and it would just fall on it's face. But my afc we also tuned. So that makes a big difference
On Cummins forum instead of working or doing homework.
97,2wd,5 spd, 150k,4510 nano,5in to 6in miter,100 plate,afc mods,egt boost fp,valair single,16*,4k gsk-60pounders,traction bars,.10 over gasket, tork tek ofv,.025 dvs, he351vgt 406hp 9-29-12
cumminsrulez is online now   Reply With Quote
Old 05-30-2012, 12:29 PM   #4 (permalink)
scott6.7's Avatar
Ok what about the guys who gut the afc, and run no fuel plate?? Mine just had literally zero power when I removed it.
Old 05-30-2012, 12:34 PM   #5 (permalink)
APWCU's Avatar
Did you slide your afc full forward when you took the plate out?
96 4x4, NV4500, Valair Kevlar/Ceramic, 4k GSK,DDP 3 Injectors, 7MM DV's, HTT 62/65/13, BHAF, 5" exhaust with Aero Turbine.
APWCU is online now   Reply With Quote
Old 05-30-2012, 12:41 PM   #6 (permalink)
scott6.7's Avatar
No not all the way forward, would that make a huge difference without the plate in?
Old 05-30-2012, 12:58 PM   #7 (permalink)
pic_jon's Avatar
Yes sir, it would make a huge difference plate or no plate.
The position of the afc housing has a very large impact on how the vehicle will run.
If mine is slid all the way back, it will hardly run. I now have it all the way forward with no plate, stock delivery valves and injectors as well as all the afc mods. Made 372/811 with a rough/baseline afc tune. After additional tuning, it's likely a hair over 400.
97 12v 2wd project: Dual-Fed 913 by Seth | 148* 7x.010" | 351cw/475/92/1.1 | Valair DD
pic_jon is offline   Reply With Quote
Old 05-30-2012, 01:10 PM   #8 (permalink)
86burbguy's Avatar
If you change the position of the AFC at all your preboost adjustment will be way off and need to be retuned for the new position. The preboost adjustment is very sensitive! 1/4 of turn from perfect to less than ideal. Moving the housing changes the preboost alot.
98 12 valve quad cab, MBRP 4 inch exhaust, triple pillar gauges, fuel plate removed, DDP's 042's, 5x12s, 4x4, 3.55 gears, 285/75/16s, KDP tabbed, AFC modded and tuned, 4GSK, + 60 vs, pusher intake, Carli 2.0 suspension kit, rebuilt trans by L.C.D. With Goerend valve body, billet input and triple disk converter. HX35/14cm over 472/1.10 .
86burbguy is offline   Reply With Quote
Old 05-30-2012, 03:23 PM   #9 (permalink)
scott6.7's Avatar
ok That was probably my issue bc when I re-installed the plate i made sure to slide the afc all the way forward.
Right now I have the #10 plate all the forward and the afc all the forward and noticed a difference.
So if i tune the afc and remove the fuel plate, slide the afc all the way forward, I should notice an additional difference from the #10 plate correct?
I Really Appreciate the help guys I know that this is probably an issue some of you guys feel like may be annoying questions and that I just need to search for it all.
Old 05-30-2012, 03:27 PM   #10 (permalink)
scott6.7's Avatar
What do you guys think of this thread???
This a good way to do it?
Please give me your opinions
afc mods (lots of pics) - DieselRam.com
Old 05-30-2012, 03:31 PM   #11 (permalink)
VP of the dry side
to me with the way ive tuned my truck i prefer to run a plate. keeps you egts cool and you can tune it easier. and with mine no matter how i tuned it it would always just fall on its face when i got to top end. grind your plate to a 100 if you want a little more power. ive never ran a 10 plate so im not sure what the power differences are
Old 05-30-2012, 04:08 PM   #12 (permalink)
scott6.7's Avatar
yeah thats what i was thinking was a 100 to see how she reacted
Seems like a significant difference between it and the ten just by looking at them
