bent shaft? initially turned the ratchet the wrong way stretching but not breaking shaft? over tightened? pull it apart and double check it....if you can spin it and see its out or whack,,, then he has something other then a balance issue....although, it all as an assembly has to be referenced to one another as individual components (blancing)
94 F350 12v it started as a test unit for fuel system parts, baselining at 451/1083... now its a full blown 2.6 truck with some bada$$ names on the side of it.
