interesting dowel pin fix.. - Dodge Cummins Diesel Forum
Old 05-24-2012, 11:43 PM   #1 (permalink)
93ford's Avatar
I dont know if I like it, can't help but wonder where the metal shavings went. But, it's done and it should work. Had already bought a tab for it but oh well. I guess this is a fix that doesn't require taking the cover off, but you gotta be a good shot and know where that pin is. I don't see the point in doing this if you already have the timing cover off.
99 f350 xlt crew cab longbed 12v 180pump
4kgsk, 60lb vs, htt 62mm, DAP 5x.012, no plate, 19* timing, 025 dvs, torktech OFV, 2095, racked barrels, holley black pusher, valair 13", nv4500, 9" lift, 37s
93ford is offline   Reply With Quote
Old 05-25-2012, 01:13 AM   #2 (permalink)
lostnwalmart's Avatar
Not the first time I have seen that.
06 vw jetta tdi
94 dodge
-Cliff
lostnwalmart is offline   Reply With Quote
Old 05-25-2012, 01:26 AM   #3 (permalink)
That was done without removing the timing cover using a KDP jig invented by John Strenkowski from Tri-County Machine in Connecticut. The engine block is under pressure using compressed air which blows the chips out instead of letting them fall into the engine. Here's a link to his site:
Tri County Machine
1998 12 valve 2500 Quad Cab,A/T,4.5" Skyjacker lift, 37.0" Goodyear MT (Humvee) Radials on Weld Typhoons.
prattman is offline   Reply With Quote
Old 05-25-2012, 08:29 AM   #4 (permalink)
93ford's Avatar
oh, very cool. never heard of that before
Old 05-25-2012, 11:18 AM   #5 (permalink)
liteweight's Avatar
Great idea as long as the dowel hasn't migrated. If it has, your pulling the cover to seat it anyhow.
liteweight
96 4X4 2500,KDP,16.5*,40hp injectors,boost elbow,3K,ground plate to 0,AFC mods,5" exh.BD pressure loc kit,lock up switch,low stall,Rebuilt trans.all billet Boost,Pyro & Trans. gauges,rear air bags,3.54's, 315/70/16's
liteweight is offline   Reply With Quote
Old 05-25-2012, 01:10 PM   #6 (permalink)
86burbguy's Avatar
I am glad I tabed mine, that would make me nervous.
98 12 valve quad cab, MBRP 4 inch exhaust, triple pillar gauges, fuel plate removed, DDP's 042's, 5x12s, 4x4, 3.55 gears, 285/75/16s, KDP tabbed, AFC modded and tuned, 4GSK, + 60 vs, pusher intake, Carli 2.0 suspension kit, rebuilt trans by L.C.D. With Goerend valve body, billet input and triple disk converter. HX35/14cm over 472/1.10 .
86burbguy is offline   Reply With Quote
Old 05-25-2012, 09:25 PM   #7 (permalink)
renopker's Avatar
There are a few jigs out there for doing it that way, beats taking it apart unless you have leaks anyway.
A stupid man's report of what a clever man says is never accurate because he unconsciously translates what he hears into something he can understand
renopker is offline   Reply With Quote
Old 05-29-2012, 08:01 AM   #8 (permalink)
glfredrick's Avatar
It is almost worth it to actually pull the cover as the front drive plate is almost always loose on the engine and the only way to re-torque the bolts is to get in there.
1995 D2500 4x4: #10 fuel plate, BHAF, turbo orfice, AFC forward, 3000 GSK, pyro & boost ga. NEXT: trans ga & filt, 4" exhaust, billet TQ, valve body.
UCORA.org -- United Christian Off-Road Alliance.
glfredrick is offline   Reply With Quote
Old 05-29-2012, 09:58 AM   #9 (permalink)
Front drive plate?
06 vw jetta tdi
94 dodge
-Cliff
Old 05-30-2012, 08:11 AM   #10 (permalink)
glfredrick's Avatar
Originally Posted by lostnwalmart View Post
Front drive plate?
Not the right name, but all the accessory drives mount on a big plate that bolts to the front of the block -- cam gear, fuel pump, power steering and vacuum pump, etc. -- and like the issue with the KDP, the bolts that hold that plate to the front of the engine are often only finger tight on our model trucks. Take them out one-by-one, lock-tite, and re-torque properly.
The whole job doesn't really take any longer than just drilling out the KDP like you are looking at, except that you have to also pull the harmonic balancer and reinstall. Also a great time to play with engine timing because you can see what you are doing.
Old 05-30-2012, 02:39 PM   #11 (permalink)
whoabeats's Avatar
I am trying to get that point across whenever I see a KDP thread. Now is the best time to mark TDC!!!!!!!!! Especially for some who may not be as confident in doing something like that. Then just make sure you put your balancer back on the correct way. Whoever did the timing on my truck before me was off by four degrees because they're tdc mark was so far off
97 2500 4x4 5spd #0 plate autometer boost fuel pressure and egt, 4kgsk w/ 60#ers, 33" Retread BFG AT's , HX35/40 hybrid, DDM Tuning 6k HID's, 98-99 HD steering swap
whoabeats is offline   Reply With Quote
Old 05-30-2012, 07:07 PM   #12 (permalink)
renopker's Avatar
The bolt holes are body drilled in the balancer the bolts have room, lots of room. Unless you put a dowel in its not going to repeat and index the same
