GSK Install HELP! plug nut wont thread. - Dodge Cummins Diesel Forum
Old 05-09-2012, 10:56 PM   #1 (permalink)
barranch's Avatar
I have spent an hour trying to put my plug nut back on. It came off easy, now it will not start back on! Can i get a new plug somewhere?
1998/3500/Quad Cab/Dually/4" exhaust/Tabbed KDP/4:10 changed to 3:54 gears/auto trans rebuilt and with triple dsk torque converter/gauges/BHAF/
stock DVs, stock injectors, stock intake/exhaust manifolds, stock turbo
barranch is offline   Reply With Quote
Old 05-09-2012, 11:10 PM   #2 (permalink)
whitlers's Avatar
Is it damaged? Anything in the threads of the pump?
96' 2500 12 valve 4x4
Mods: 2" leveling kit, bags, Fox shocks, BD guages, #100 fuel plate, AFC mods, 3 GSK, 60 lb valve springs, boost elbow, BHAF, 4" exhuast, 475 hp Southbend, Pac-Brake
whitlers is offline   Reply With Quote
Old 05-09-2012, 11:12 PM   #3 (permalink)
Injector Pump Plug Nut
Illflem said "Turn it backwards, counter clockwise, till you feel the threads drop in then turn it the right way. "
That does work often when trying to thread a bolt that is plain ornery.
1997 3500 club cab Automatic 3.54 gears towing and camper package. Still stock with 116k on it so far. 4" dynomax stainless exhaust, 4kgsk, and pacbrake exhaust brake waiting for installation. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline   Reply With Quote
The Following User Says Thank You to country_hick For This Useful Post:
barranch (05-09-2012)
Old 05-09-2012, 11:15 PM   #4 (permalink)
barranch's Avatar
the threads are flat at the start of the plug, then they start to raise after the second thread. It has never been removed before. Having one hell of a time getting it on again.
Old 05-09-2012, 11:18 PM   #5 (permalink)
barranch's Avatar
Thanks i will give it a try tomorrow after work, I have had enough tonight
Old 05-10-2012, 09:33 AM   #6 (permalink)
I had this same problem when i did mine last week. Try using a socket and a small extension and turn very slowy. I found that a smaller 3/8 drive socket worked best. Goodluck.
97 3500 5spd, 4wd, 190,000, #100 plate ff, afc mods, 4gsk, cai, 5 inch pipe, autometer boost, pyro, and fuel pressure gauges
Cummins 24 is offline   Reply With Quote
The Following User Says Thank You to Cummins 24 For This Useful Post:
barranch (05-10-2012)
Old 05-10-2012, 07:17 PM   #7 (permalink)
barranch's Avatar
why the @#$! did i take this thing off! Another 45mins down the tube, ugghh!
Old 05-10-2012, 07:36 PM   #8 (permalink)
barranch's Avatar
does anyone know where i can get a new plug? I am willing to try anything, this is ridiculous
Old 05-10-2012, 08:16 PM   #9 (permalink)
MotorCityMadman's Avatar
Try sharpening the threads with a triangular file. I know I had a heck of a time getting mine started.
96, 2500, #10 ff, elbow,3gsk,2095, .024s,50hp nozzles, gauges,WVO, B164 bypass
2004.5, 3500, SRW, FASS pumped WVO, B164 bypass, Edge/Att 98 2500 eclb 4x4auto,48re vb, billet single,shift kit+, hx35/40, 4" ss, BHAF,16*
MotorCityMadman is offline   Reply With Quote
Old 05-10-2012, 09:20 PM   #10 (permalink)
barranch's Avatar
i think i am going to call the stealership tomorrow and see if i can order a new plug.
Old 05-10-2012, 10:03 PM   #11 (permalink)
Had the same problem. The lip on the plug was rubbing on something. I don't remember what it was, a bracket or something. Just grind some of it off and try it.
98 2500 QCLB 4X4: G56 SIX SPEED: VALAIR DD CLUTCH: DANA 80 W/ 3.54 GEARS: 315/75-16 RUBBER: COLD AIR INTAKE: #10 PLATE: ADJ. BOOST ELBOW: 4K GSK: 60# VALVE SPRINGS: AFC MODDED: KPD TABBED: HX35 W/ 4" POWER ELBOW: 4" EXHAUST.
Ed Font is offline   Reply With Quote
Old 05-10-2012, 10:32 PM   #12 (permalink)
VP of the dry side
cumminsrulez's Avatar
i had the exact same problem. its not the nut. at least i highly doubt it. i had to take the little arm off that sits right next to the hole to get it off. just loosin a little set nut on it and pull the arm off then you can line the plug up waaayyy easier and it wont rub on anything. i took that arm off and had it on in 5 minutes
97,2wd,5 spd, 150k,4510 nano,5in to 6in miter,100 plate,afc mods,egt boost fp,valair single,16*,4k gsk-60pounders,traction bars,.10 over gasket, tork tek ofv,.025 dvs, he351vgt 406hp 9-29-12
cumminsrulez is online now   Reply With Quote
